passing with no cats help!!!
hey guys heres the deal found a killer deal on a brand new bassani off road x and with my borla stingers thats a dead sexy combo only thing im worried about is living in ny ....and passing emissions test ...when i go for an inspection they never put my car on the lift they just plug it into the comp and press start button and it runs the test ...so i was told if i got a tune to shut off the rear 02 sensors i would be good to go .....?? any ideas / suggestions ..do i just shell out the $ and get the high flow catted x ???? please help
If you get the Bassani X pipe for street use, it actually comes with cat deletes too (I have this). Put the cats back in for smog, then remove again.
Your car will not pass without cats.
In Texas it would. For obd2 It only has to pass a computer scan. Ie if you have a check engine light it will fail. Getting a tuner to shut the back two off..certainly. as long as your tint is right and your lights/horn all work your good. I would get them to put the handheld obd scanner to be sure. Once its 95 or older emissions testing ex. tailpipe Sniffer comes into play but no obd scan is required. Funny huh. I just do what the dps tells me to do. What state are You in
Edit Just saw NY
Edit Just saw NY
Edit Just saw NY
Edit Just saw NY
Originally Posted by DaTT(1sK)
I believe the scan checks for changes to the computer too...
Ny will not pass the car. They do a safety inspection as well and will not pass you without them- they lift the car and check the underside, wheels, brakes, etc... You can have high flows welded in or change it back to stock everytime you go in.
Edit Just saw NY
Edit Just saw NY
Originally Posted by Kona Blur
So you think I'd be able to pass here in TCif I get these Borla LTs w/ no cats? How much difference will having/not having cats make performance-wise? Never dealt with anything past the axle before...
