passing with no cats help!!!
Old Aug 9, 2011 | 11:36 AM
BRUISEDGTCS's Avatar
hey guys heres the deal found a killer deal on a brand new bassani off road x and with my borla stingers thats a dead sexy combo only thing im worried about is living in ny ....and passing emissions test ...when i go for an inspection they never put my car on the lift they just plug it into the comp and press start button and it runs the test ...so i was told if i got a tune to shut off the rear 02 sensors i would be good to go .....?? any ideas / suggestions ..do i just shell out the $ and get the high flow catted x ???? please help
Old Aug 9, 2011 | 12:01 PM
B1STANG's Avatar
Weld the stock cats on or go w/ the hi flow cats. I'm in MA and we have the same issues. I'm getting catted H and save myself the headache
Old Aug 9, 2011 | 02:00 PM
sinisterbullitt's Avatar
There's always the money option.
Old Aug 10, 2011 | 04:17 AM
DaTT(1sK)'s Avatar
If you get the Bassani X pipe for street use, it actually comes with cat deletes too (I have this). Put the cats back in for smog, then remove again.
Your car will not pass without cats.
Old Aug 10, 2011 | 03:17 PM
In Texas it would. For obd2 It only has to pass a computer scan. Ie if you have a check engine light it will fail. Getting a tuner to shut the back two off..certainly. as long as your tint is right and your lights/horn all work your good. I would get them to put the handheld obd scanner to be sure. Once its 95 or older emissions testing ex. tailpipe Sniffer comes into play but no obd scan is required. Funny huh. I just do what the dps tells me to do. What state are You in
Edit Just saw NY
Old Aug 10, 2011 | 04:21 PM
dunarze's Avatar
Well since its already illegal to run without cats you probably already know that you can find a place that will pass if you if you hand them a Big Ben
Old Aug 11, 2011 | 04:38 AM
DaTT(1sK)'s Avatar
Edit Just saw NY
I believe the scan checks for changes to the computer too...
Old Aug 11, 2011 | 07:06 PM
Not sure about that one I can check into it. It wouldn't really be a change right its tricking the computer into thinking its normal
Old Aug 12, 2011 | 01:07 PM
DaTT(1sK)'s Avatar
I believe it would detect if any of the emissions sensors have been altered or shut off.
Old Aug 12, 2011 | 03:20 PM
ARSMITH25's Avatar
Check this out
http://www.s197forum.com/forum/showt...=Emission+test
Old Aug 15, 2011 | 08:03 AM
bob's Avatar
bob
Why not just shell out the money for the catted intermediate pipe? Its alot better than spewing untreated crap from the exhaust.
Old Aug 15, 2011 | 09:12 AM
DynamicmustangGT's Avatar
Ny will not pass the car. They do a safety inspection as well and will not pass you without them- they lift the car and check the underside, wheels, brakes, etc... You can have high flows welded in or change it back to stock everytime you go in.
Old Aug 15, 2011 | 10:11 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Find someone who will get you a "special" sticker.
Old Aug 16, 2011 | 03:58 PM
Its true best to go to a car show and ask around. Look for up to date stickers on clearly not passable cars. Ask who did it. Have a hundred bucks ready
Old Aug 16, 2011 | 04:01 PM
AlsCobra's Avatar
A Man Just Needs Some....
Does NY actually do a smog test(probe in the tail pipe)? If you turn off your 02's, the readiness monitors will be incomplete and you will fail.
Old Aug 16, 2011 | 04:08 PM
Kona Blur's Avatar
Edit Just saw NY
So you think I'd be able to pass here in TCif I get these Borla LTs w/ no cats? How much difference will having/not having cats make performance-wise? Never dealt with anything past the axle before...
Old Aug 16, 2011 | 04:09 PM
Kona Blur's Avatar
Edit: TX
Old Aug 16, 2011 | 09:24 PM
Where at in Texas. There some emissions free zones scattered where it is safety only
Old Aug 17, 2011 | 10:06 AM
Kona Blur's Avatar
I'm always back and forth between Austin and Houston for work so either one...
Old Dec 26, 2011 | 09:57 AM
mdelao's Avatar
Do you guys know if I remove the cats the check engine will appear?
