Oil question (not the typical one)
Thanks for all the input guys. I finally called Ford customer service in an effort to get to the bottom of this. After going through all the pleasantries (What’s Kuwait? Where’s that? What are ya doin there?…) I explained my situation. The rep seemed very concerned, said that this should not be, and that Ford will go after that dealership, because at the end of the day its Ford that will have to cover the warranty. He asked for my number and email and left me feeling very bad about what damage I may have done to my car.
Less than 15 minutes later, the regional manager of Ford MENA (MidEast & North Africa) called me and explained to me that Ford engineers actually recommend using 10w30 in the climate of this part of the world. He even said that using 5w20 will cause some serious oil shearing in the summer heat. He further explained that the difference between the two is minimal in cold flow viscosity and that the pump will not have to work harder. Even if I find 5w20 here, he said it would still be better to use the 10w30.
Thanks for all your help. As usual, this forum never disappoints.
so how many others here run 5w-30 instead of 5w-20?
I ask because I am about to change over to synthetic( im at 5k miles) and costco had 6 quarts on sale, but only in 5w30.
I run 5-30 for now as a bit of an experiment. I check my used oil with analysis every oil change, and I had good luck with 5-30 Mobil 1. I then switched back to Pennzoil Platinum 5-20 and my wear metals went up slightly. I'm going back to 5-30 to see if my wear goes back down again.
Super Moderator
TMS Staff
TMS Staff
Again,
The 5W20 is to meet the CAFE Ratings only, you can run 5W30 without any problems.
However, Synthetic 5W20 will provide a Viscosity / Sheer rating greater than most petroleum oils, and still protect the engine in both hot & cold situations.
Remeber, NASCAR teams use straight 0 weight for qualifing and in certain race applications. I know I supply it to them.
However it is SYNTHETIC.
TDS
TDS
I don't see a problem with that. You're in Chicago, so it gets fairly cold there. I don't think I would run it past winter though, with you being supercharged and all. A 5-30 would provide some extra protection for you in the summer with your added HP.
Yea I don't think it will be an issue either. When the engine is up to temperature it will still act like a 20W. I just want the protection under initial startup for my supercharger.
Rando
8/25/21 11:12 AM
