OIL CHANGE INTERVALS /MOBILE 1
Old Oct 20, 2005 | 06:42 PM
Hugo6705's Avatar
You Mobile 1 users ... what mileage intervals are you changing you oil? In lieu of 3000 miles, what's your opinion of 5000 miles interval?
Old Oct 20, 2005 | 07:51 PM
Ugly Ernie's Avatar
I've used Mobil 1 in everything for years. I change it at 3000 & just figure it is cheap insurance! If I were going to run it 5000 I'd still change the filter at 3000. I always cut my filters apart & check for particles. If a filter would ever fill up (plug up) they have a spring by-pass & you would be circulating unfiltered oil.
Old Oct 20, 2005 | 08:35 PM
ex-Galaxie500's Avatar
I've only changed it once and that was from the oil and filter from the factory to Mobil 1 and a K&N filter @ 3,025 miles. I plan to do it every 3,000 miles, even though I know synthetic is designed to and does last longer, I don't mind spending the extra money to do it as I always have
Old Oct 20, 2005 | 08:41 PM
TheWrench's Avatar
I used Mobil 1 oil and filter for my first oil change at 1100 miles. I plan to do it again at 3k and then every 3k after. I hear you can run it to 5k miles but I don't mind every 3k for peace of mind.
Old Oct 20, 2005 | 09:13 PM
alfman9's Avatar
Dude, you have to let me in on this trick. How do you change the oil filter without changing the Oil???
Synthetics are good for 5000 on abused street cars. Even longer if you arent hard on it.
Old Oct 20, 2005 | 09:44 PM
Fazm's Avatar
When you remove the oil filter, only the oil in the fitler and a lil more in the housing come out. You just put on a new filter, and top it off with oil. Oil is only circulated through the housing when the car is running (oil pump running)
Old Oct 20, 2005 | 09:59 PM
GRAYPNY's Avatar
4000 miles or 4 months. The months will probably come quicker.
Old Oct 21, 2005 | 04:47 AM
ponyboy66's Avatar
3000 for me.
1st change at 1050.
Send out my oil for analysis for a 20 spot.
Old Oct 21, 2005 | 05:31 AM
outdoorstom's Avatar
Originally posted by ponyboy66@October 21, 2005, 4:50 AM
3000 for me.
1st change at 1050.
What were the results of the analysis? No surprises, right?
Old Oct 21, 2005 | 06:13 AM
slammer223's Avatar
I put Motorcraft synthetic blend on the first change two weeks ago (2900) but the next change will be Mobil 1 and every 3000 to 5000 after that. Sometimes it depends on when I can get to it, the dealer or anyone else won't be changing mine! I feel completely safe letting it go till 5000. That is based on the 79 Skyhawk I had way back when...I changed it every 10000. That motor looked like new when I had the valve covers off. The car went 150000 before I traded it. I don't recall my logic for letting it go that long, maybe just to see what would happen.
Old Oct 21, 2005 | 06:24 AM
EleanorsMine's Avatar
After all these years,
My C/T still sucks!
How bout next time I see you in Hoover you hand over the keys and I will answer that in my garage?
I do every 5,000 miles.
Old Oct 21, 2005 | 06:57 AM
LLG05's Avatar
Originally posted by slammer223@October 21, 2005, 6:16 AM
I changed it every 10000. I don't recall my logic for letting it go that long, maybe just to see what would happen.
Or, maybe your smarter than you thought?
http://www.motoroilbible.com/index.html
I run Amsoil 0W30 Synthetic oil & their filter. I will do both every 10,000!
Dave...
Old Oct 21, 2005 | 07:15 AM
tw0scoops123's Avatar
I have mobil 1 and I'm doing every 5k miles. My reasoning is the oil is more resiliant and will last longer than standard oils. Plus the recommended oil change for the GT is 5k anyway. Plus expense comes into play since its about 40 bucks and oil change(oil + filter).
Old Oct 21, 2005 | 07:39 AM
slammer223's Avatar
That's the first time anyone said that to me!
But seriously, let me know via PM or whatever how you make out with Amsoil and extended drain interval. I've used their products in the past also.
Old Oct 21, 2005 | 08:36 AM
LLG05's Avatar
Sure, will do. I changed my oil, using Ford's Factory Oil at 500, 1500, then 3000. I put the Amsoil in at 6000 and currenty have 12,200 on now. I have not lost a drop of oil, and she runs like a rape-dape! I also have the Predator 87 tune on my stock motor! When I change the oil, I will also send some out to be analyzed, just to see how it is. I also have one of these, inside my oil filter now!
http://www.kjmagnetics.com/proddetai...d=D66SH&cat=13
It's just a little extra protection. Every little bit helps. I had one these magnets in my oil filter at the 3000 mile change and when I took the filter off at 6000, believe-you-me, that magnet was very fuzzy with shaving! At my next change, I'll try to remember to take a picture of the magnet to show you what it caught.
Dave...
Old Oct 21, 2005 | 08:58 AM
jcopin's Avatar
i used to change my oil every 9k in my 96 mustang V6 and never had a single engine problem till car was totalled at 136k
Old Oct 21, 2005 | 09:30 AM
Martimus's Avatar
I first changed the oil in my car at 1500 miles and at 3000 mile intervals ever since, motorcraft oil and filters. At 10000 miles I switched over to Mobil One oil and filter and am really happy with the change. Historically all of my cars over the last decade or so have run on Mobil One.
Old Oct 21, 2005 | 09:39 AM
Knight's Avatar
Needs to be more Astony
I use this mobil 1 synthetic 15000 mile oil...but i change it every 10-12k miles..
Old Oct 21, 2005 | 09:45 AM
maniak's Avatar
I haven't change the oil on our mustang yet (only 3 days old.. 300 miles)...
But.. Our 92 explorer gets its oil changed every 8000 miles (mostly highway with occasional hard four wheeling).. If I happen to do a bunch of driving in dusty conditions (one of the trails i go to has a 30 mile drive on a dusty/dirt road..) I change the oil, oil filter and air filter when I get back.. The explorer now has 320k miles (orig motor)...
Our 95 neon gets its oil/filter changed about the same interval.. and it now has 293k miles on it..
I'm a beliver in full synthetic (mobile 1 is what we use) and good filters..
~Mark
Old Oct 21, 2005 | 11:14 AM
MTAS's Avatar
I use Mobil1 5w20, change oil and filter every 3mo or 5K, which ever comes first.
