O7 gt computer problems
Old Mar 17, 2017 | 09:00 PM
Jamie Brookshear's Avatar
Will a ecm out of a automatic work in a manual car
Old Mar 18, 2017 | 08:26 PM
houtex's Avatar
With an 'automatic' computer, the automatic transmission is expected to talk to the engine, if you will, to let it all work together, and if the computer doesn't see the transmission, it's going to throw codes like no tomorrow and not run right. You'll never pass inspection again.
It's not that it wouldn't run the engine... it likely will run, sure, but...
Get the correct computer for the car, and avoid problems.
Hope that helps, good luck!
Old Mar 18, 2017 | 09:11 PM
Gigantor's Avatar
If you do get an ecm from an automatic you'll have to get it flashed. If you have a handheld tuner and lets say "Tunes for Life" from Bama I'm sure they could give you a tune what will work with a manual transmission.
Old Mar 19, 2017 | 09:07 AM
I found 1 for a manual thanks for the advice and help
