Noisy Brakes
Old Oct 24, 2005 | 03:20 PM
lethaljay's Avatar
I tried searching for a thread that talks about this but I couldn't find one. Well maybe my car is just "unique". Well, here is my situation, Kansas has just finally experienced some cooler weather and my brakes must hate it. Every time I turn into my driveway *turning to the left* there is a screeching sound coming from the rear of the car. Also when ever the car hasn’t been driven in a couple of hours and you press the brake pedal to slow down the brakes squeal like there is no brake pads and it's just metal against metal. I can't imagine going through a set of brakes with only 3,200 miles on the clock.
Also, whenever I'm not driving on a PERFECTLY smooth road there is a rattle coming from the passenger side in the back. My car sounds like a hunk of junk!!! Help me restore the greatness of this beast! :bang:
Old Oct 24, 2005 | 04:04 PM
Red Ryder's Avatar
There is a TSB that addresses your rear brake noise. They will replace your pads for free.
I'm sure the dealer will findout what that rattle in the back is when you have the car in for service .....
Good luck. I'm sure everything will be just fine when your done......
Old Oct 24, 2005 | 04:22 PM
Boomer's Avatar
They replace the Disc Brake Lining for the rear end squeak.
I'm getting it done on friday.
Check out the TSB in the TSB thread
Old Oct 24, 2005 | 05:27 PM
lethaljay's Avatar
Does it matter that my car was built AFTER march 8th?
Old Oct 27, 2005 | 09:17 AM
Mtang78's Avatar
Problem is I've had this squeaky brake problem for a few months and have taken it into the local dealer 2-3 times. The second time I took it in at 15,000 miles, they turned my rotors without asking. No pulsating brakes, just squeaking. TSB says specifically not to turn the rotors, but the TSB came out after the rotors were turned. I took the TSB back into the dealer and they performed the warranty under the TSB, but get this -- they did NOT replace my rotors! I'm PO'd as could be. First of all, I did not authorize them to turn the rotors in the first place. Secondly, the brakes were not pulsating, I only complained they were squeaking. The rotors should have NEVER been turned. And finally, by turning the rotors, they have diminished the life of the rotors. To quote them, they said "they are in specs". Obviously, DUH! They were in spec to begin with. Those rotors didn't need turned and I didn't authorize them to do so. To me, there is no difference between complaining about squeaky brakes and turning the rotors without authorization, or complaining about an engine noise and replacing engine components without authorization.
Old Oct 31, 2005 | 01:24 PM
Boomer's Avatar
Had this TSB done on Friday, and it works.... my brakes no longer call dogs to come after me and chomp on my biscuits....
Old Nov 7, 2005 | 08:32 AM
Stadifer's Avatar
Good to see this one because my breaks just started to squeek!
Old Nov 7, 2005 | 10:51 AM
Boomer's Avatar
I am mistaken in the first post above... they DID replace the brakes...
My bad..
And yes, no worries, it fixes the problem
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 8, 2015 10:45 AM
