Noise when engaging clutch in first gear
Old Dec 13, 2006 | 12:16 PM
shatter's Avatar
Question Noise when engaging clutch in first gear
I did a quick search and didn't see this specifically. I have a 2007 GT w/ 5-sp manual with 600 miles and I noticed today that when I let the clutch out starting in first gear from a stop that I hear a little bit of chatter that lasts about a second or so and then goes away. The slower the engine RPM the more noticable it seems. Should I be concerned?
Also, when I put the car away tiime before last and turned the engine off I had the clutch pedal depressed fully and the car in first gear but at a complete stop, the car made a loud noise like a blower or tubo winding down. I could not get it to repeat since (only tried 3 times). Any ideas? Some freak thing?
Thanks!
Old Dec 13, 2006 | 05:29 PM
Robbieg's Avatar
I also have an '07 with about 450 miles and I have started noticing the same noise at very low barley rolling speed in first, I don't know if its normal or not, its almost like a gear whining, definitely coming from the tranny.
Old Dec 13, 2006 | 08:14 PM
shaun_beauchamp's Avatar
14,700 miles of the same darn noise. I have had that noise since day 1, mile 1 and my dealer assures me it is fine. I have driven this car all over the US and no issues. So I continue until something gives, but I consider it normal. Why first gear? I have mine do it in reverse too. Maybe something to do with engine spinning and driveline not until a certain point when they just mesh. If you do it from a slow roll in first it does it too, but if you go to second during a slow roll, no noise?
Keep driving them. We'll all go to the dealer together when they let loose!
Old Dec 14, 2006 | 12:29 AM
official_style's Avatar
probably the clutch is glazed. peel out a few times, this usually fixes it. turbine noise is normal. some trans whine/noise is normal, these trannys are noisy! but you bought a mustang a not a benz!
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Gill5oh
Oct 6, 2017 10:50 PM
ricky1728
Feb 11, 2016 07:25 PM
