No start when hot..
No start when hot..
Hey guys new member here and pls forgive me in advance if I posted in the wrong forum. Love all u guys for the great info u all post to help others with their technical issues.. I have one and maybe u guys can help. I have a 08 GT with just ur basic bolt ons..CAI .. Bama tuner .. Under drive pulley exhuast from the cat backs with 373 rears.. My problem is this .. And it just started happening. On a cold start the stang starts up fine ..runs good no issues .. But once I shut it off.. She cranks but doesn't start.. I have to wait till she cools off a bit and when she does .. She comes right back on.. No CEL .. Nothing .. And it's racking my brain. Something is over heating and I don't know what it is . I even hear the fuel pump coming on.. But nothing when she's hot. Maybe the fuel pump relay? I don't know.. Any advice would be greatly appreciated .
Check your battery too, mine was going bad and when I stopped for a short time while and the engine was hot, it wouldn't start. The battery would heat soak and since it was weak it wouldn't start till it cooled down.
This could be caused by a few things as some have mentioned.
If it only happens when hot it could be vapor lock. Fuel line to close to the engine gets hot and it will boil and will not flow correctly. The other thing is did you check the spark? I have seen coils go bad and not work when they are hot.
Good luck those are fun to trouble shoot as the engine has to be hot.
Have you tried to clear the cylinders when this happens? Maybe 4-5 times in all the years I've had my car it has done this. I usually clear the cylinders and keep cranking as I return the throttle to zero and she starts right up. Don't have any explanation why this is, just my experience.
Well guys thanks for the great advice..
I swapped out the fuel pump relay and still having the same issue .. But I did realize when she's hot .. I don't hear the fuel pump priming .. But when it was raining here a few days ago .. I drove her to work .. Shut her off and guess what .. She started right up.. Maybe the rain was cooling off something underneath.. I do notice .. When I am in the car .. It's incredibly hot at times . Now mind u.. I have a GT 500 tranny in the car.. That's how I purchased it .. Not from the dealer of course . I changed he spark plugs .. And the coil packs look good .. Haven't gotten to the other stuff.. Yet.. I know it's something stupid causing the problem.. My friend said it could be the wire harness.. But I don't think so. Any more advice will be appreciated . Thanks .
I would recommend taking your car to either a shop or local dealer and have your electrical system tested.. Until you have the system diagnosed, you're just pretty much spinning your wheels and grasping at straws not knowing exactly what's causing your car not to turn over when it's warm.. Anyway just my opinion
If you hold the pedal to the floor while cranking the starter it cuts off the fuel injectors. This allows you to clear the cylinders of any fuel that may be in there. Basically helps if the engine gets flooded for some reason. I have found in my 20 or so no start scenarios when hot, that holding the pedal to the floor while cranking and then letting off back to the idle position while still cranking the motor will start her right up.
It happened yesterday with me. I stopped to get gas and the card reader wasn't working so I immediately tried to start her up to move to another pump. Cranked but wouldn't fire up. Pressed the pedal to the floor and started cranking. While continuing to hold the key in the start position I released the pedal and she fired right up. I don't know why she occasionally does this but it is only when I immediately try and restart the car when she's hot. It is a rare occurrence and happens only about 2-3 times a year.
I only mention it as it is something to try without costing any money. I suspect it may be a tune thing but it's never been much of an issue.
![Unhappy](https://themustangsource.com/forums/images/icons/icon9.gif)
09 ford mustang GT premium won't start
I checked the battery and altenator, starter cables
radio was off and dash started to flash and radio came on making noise all by itself. I haven't a clue does anyone have any ideas I just purchase this car with 57000 miles on it.
It means that it's time to replace the battery.. Whenever your dash flashes and radio comes on by itself making noises, your battery is nearly completely discharged.. Try jump starting or use a battery charger.. If your car still doesn't start, your battery is toast..
