New stang has rusty rear
Old Oct 11, 2006 | 07:32 PM
silver06's Avatar
Exclamation New stang has rusty rear
Has anybody else seen this on there new stang? I have an 06 with 100 miles on it, theres not another spot underneath the car that has rust except this spot. Should I be worried about this and take it back to the dealership? It looks like surface rust, I can't see any pitting in the metal yet!
Attached Thumbnails New stang has rusty rear-website-1.jpg   New stang has rusty rear-website-2.jpg   New stang has rusty rear-website-4.jpg   New stang has rusty rear-wesite-3.jpg
Old Oct 11, 2006 | 07:46 PM
sad but normal sorry to say. There's no protective coating on the rear end so it will rust. It will out last us all if that makes you feel any better. You can paint it if you want to
Old Oct 11, 2006 | 07:48 PM
bob's Avatar
bob
Ehhhh.... your okay, its not a problem, just unsightly, If it bothers you a bit to much, get under there with a wire brush and siome steel wool then paint it black, or just takes some steel wool and knock the big rust off and paint it black, or just paint it black.
Old Oct 11, 2006 | 07:57 PM
karman's Avatar
I just never have had it out in the rain ever. Ordered it and grabbed it as soon as it hit the lot (1 hr.)
Old Oct 11, 2006 | 08:15 PM
TexaStang's Avatar
Coulda been rain/alot of moisture at the plant when yer car was made.
Old Oct 11, 2006 | 08:23 PM
silver06's Avatar
Thanks for the info! I'll probably just leave it until I do the exhaust!
Old Oct 11, 2006 | 08:46 PM
steevr's Avatar
Silver,
Here's a pic I just took off my '07. I've got 1,300 miles, but it's also never been in the rain. I bet all it takes is one or two times of getting wet and it gets full of surface rust.....ever notice a disc brake rotor on a car that's sat outside for two days....same thing.
Old Oct 12, 2006 | 12:03 AM
Gearhead's Avatar
I painted mine with black hammerite, and it worked great! It dries very quickly (about 15 minutes) and doesn't require any more surface prep than just a quick mineral spirit wipe. One word of caution: mask over your axle identification tags very well before you approach them with mineral spirits, or else they will get erased.
Old Oct 12, 2006 | 04:55 AM
metroplex's Avatar
steevr: In which state do you reside?
Every Ford we own with a RWD rear-end made by Ford has light surface rust. It is nothing to be concerned about. My 1981 T-bird's 7.5" has had 26 years worth of rust and its still holding up. The underbody, however, is another story!
Old Oct 12, 2006 | 02:46 PM
Tedz Pony's Avatar
I had the same worry with mine, but went to the dealer and they said what everyone else here says - No big deal, normal. So, don't worry about it. Mine came off the lot that way, because I noticed it the day I got it home.
Old Oct 12, 2006 | 02:53 PM
metroplex's Avatar
I'm curious if anyone here has ever owned another RWD Ford? Because the rear end ALWAYS rusts unless you paint the axle. My 00 Vic was delivered straight from the factory with rust on the surface of the axles and pumpkin.
Old Oct 12, 2006 | 03:05 PM
mrkabc's Avatar
No big deal on the rust. No one will see it anyway. If you are planning on taking the car to shows though you might want to put some naval jelly on the rust and then paint.
Old Oct 13, 2006 | 10:55 AM
paperthinhymn's Avatar
powdercoat it!! that would be the best thing
Old Oct 13, 2006 | 04:50 PM
Stangers's Avatar
Don't worry about the rust.T-Rex and 3ft flyin roaches will be back before that rear rusts to the bone.
Fords4Ever
Oct 30, 2015 09:07 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Savior Six
Sep 24, 2015 06:35 PM
Sep 16, 2015 06:44 PM
Gabe
Sep 7, 2015 03:30 PM
