Need help!
Need help!
How much air is supposed to be in the stock tires?
I've got stock 18" 'blades. i had the wheels rotated for the first time about a month ago and the car has been all squirrely ever since.
On a hunch that the tire pressure had been f^#*ed with i checked it and all four tires were right at 40lbs.
This seems a bit high to me, as I have always heard around 32-35, but, these stock BFGs are somewhat "low profile" so may be higher is better. I see no recommended presure on the tire, only a "do not exceed 44 lbs" warning. The door sticker says 32 lbs.
I lowered them to 32lbs, but was I right????
Seriously, I need to know.
This may help (read down to find pressure discussion).
http://forums.bradbarnett.net/showthread.php?t=74481
