In need of advice, is a heat exchanger worth it?
Old Jun 4, 2016 | 08:58 AM
M90CaliforniaSpecial's Avatar
Hey guys, just picked up my California Special a few weeks ago and looking to do a few modifications. Bought the car with a m90 Roush Charger and I've been reading soo much about heat soaking. I live in Florida where its either too hot or hot at all times so I'm wondering if the heat soaking would especially apply to my car. Im not looking by any means to have a extremely fast car or I would ditch the m90, I just want to make sure I'm getting the most I can out of my setup which is sufficient for me. Btw I do plan on doing the smaller pulley, tune and gears which should all be done around May sometime, with this thread I just wanted everyones opinions on if a heat exchanger is worth the $1,000 its going to cost in the end. I was looking at this one in particular http://www.vmpperformance.com/VMP-Du...vmphe-dual.htm.
Old Jun 4, 2016 | 11:36 AM
SplitSecond's Avatar
You are definitely in the risk for heat soak, it just comes with the territory with supercharged applications. Without a proper heat exchanger your intake temps will be through the roof in the Florida heat and your power will be way down. The higher the intake temp, the lower the power.
Personally I would contact Department of Boost and see what they recommend for your setup. It doesnt look like thier website has been updated in a while, but he is an active member on here.
Old Jun 4, 2016 | 03:07 PM
That's the route to go. If I do modifications to my car, it will be with the VMP dual fan triple pass heat extractor. No question about it.
Good luck and let us know!
Old Jun 4, 2016 | 10:11 PM
Definitely worth it and you've gotta have a heat exchanger and bigger is better when you're in south Texas or Florida heat. Gotta cool that intake air.
Old Jun 5, 2016 | 10:28 AM
Sounds pretty unanimous, the heat exchanger is a must...
Old Jun 6, 2016 | 02:16 AM
kcoTiger's Avatar
heat soak on a blown motor is so bad, I went to a liquid-cooled blower in addition to the heat exchanger already on the car. It will absolutely kill your HP and once it's soaked, it'll take a good hour before you can get any more power out of it. I live in Texas, there's no such thing as too much cooling on a blown motor.
Old Jun 7, 2016 | 04:03 AM
wlarryf's Avatar
If you have the budget then get one. It can help lower intake temps and dissipate the heat in the intercooler.
Old Jun 7, 2016 | 10:04 AM
Definitely going for it. After more research I haven't found a single person to say anything less then good reviews from doing it and I feel its necessary in the Florida humidity and heat.
Old Jun 7, 2016 | 10:41 AM
Evil_Capri's Avatar
What year is you California Special? (Asking so your thread can be moved to the proper section.)
Old Jun 7, 2016 | 12:41 PM
ford20's Avatar
Considering it is an M90 I would say 05-09
Old Jun 7, 2016 | 12:46 PM
Evil_Capri's Avatar
Thanks ford20 . . . and to me for not paying closer attention . .
Old Jun 7, 2016 | 02:16 PM
Bert's Avatar
Wait -- your car already has a heat exhanger, right? Meaning the extra radiator mounted low in the front?
Upgrading it might help . . . or maybe not . . . as I understand it, the weak points in the M90 are:
- the intercooler -- this is inside the manifold, and will not be changed with a heat exchanger upgrade
- the M90 supercharger itself -- it is a bit undersized for our engines, so you have to spin it fairly fast to make decent boost, and that causes it to run hot
I think you do NOT want to go to a smaller pulley to spin it faster; that will just make the heat problem worse.
And yes talk to Jason at Department of Boost, he knows these blowers better than anyone, especially in the area of heat issues, and he will give you the straight scoop.
Old Jun 8, 2016 | 07:52 AM
07 Boss's Avatar
I agree, going to a smaller pulley may not be the wisest decision. Every blower has an efficiency range and when you get out of that you may not see any gains due to loss in efficiency. But with that said, heat is the enemy. Any way to reduce heat is a plus.
If you want more power I might look at a different/bigger blower.
Old Jun 10, 2016 | 09:22 AM
Evil, 2007. My bad if I posted in the wrong section, still trying to get a hang of the site.
Old Jun 10, 2016 | 09:31 AM
m90
The pulley should only give another 2 lbs and I defiantly agree that with only that upgrade I am kinda fighting the gains due to the added heat. Im not trying to make an extremely fast car, I just want to be as efficient as possible with what I have. I know I have to do something about the additional heat and thanks to Bert ill be researching all day about whether to upgrade the intercooler or go with the heat exchanger. End goal I'm looking for 450 rwhp which, from what I've been told, shouldn't be difficult with the m90, pulley, exhaust, intake and tune.
Old Jun 10, 2016 | 09:55 AM
Bert's Avatar
If you can get ahold of Jason at DOB, he can probably give you some quick answers, I think he has been there and done all of this:
http://departmentofboost.com/
departmentofboost@yahoo.com
http://www.departmentofboost.com/vbull/forum.php
Old Jun 10, 2016 | 11:43 AM
New idea, just got off the phone with a friend who quickly and without a doubt recommended the Killer Chiller unit over the HE. After reading reviews and researching for the last 2 hours I have yet to read anything but absolutely great reviews. Only negative thing I see is a reduction in the AC in cabin but I can live with that. Thoughts? Thanks Bert, I'll definitely try and get a hold of DOB
Jack Straw
32
Jun 23, 2016 09:07 AM
buckethead1
May 19, 2016 12:18 AM
ghost3.7
May 15, 2016 01:40 PM
JeremyLee
West Coast
May 9, 2016 01:17 PM
