Mysterious exhaust pop at idle
Old Dec 17, 2014 | 06:12 PM
Levine's Avatar
Hi all !
So I bought 05 v6 5 speed this summer. Very recently, I accidentally noticed that at idle it makes very subtle exhaust pop. Also, once after sitting in a traffic jam for 1 hour the car gave me check engine light that disappeared later with no traces (none in ODBII history).
FYI, I did change the spark plugs, wires and coil pack just for a good measure ,right after I bought the car.
Do you have any ideas as to what this might be ?
Should I be worried about this? I think the pop is a result of a misfire which could damage catalytic converters. But why is it so subtle and only on idle ?
In the video you can hear the popping at around 1:20
Old Dec 18, 2014 | 09:57 AM
KdF's Avatar
KdF
Clean the Throttle Body!
Old Dec 18, 2014 | 10:09 AM
fixmejesus's Avatar
Speed Buggy Returns!!
Old Dec 19, 2014 | 12:51 PM
Levine's Avatar
Thanks for the suggestion. Can you say why you think I should clean it ?
Old Dec 19, 2014 | 01:18 PM
KdF's Avatar
KdF
Throttle Bodies are notorious for giving out strange problems, and most find that a cleaning is simple, cheap and surprisingly clear a lot of hesitation and response troubles. Do the simple things 1st.
Old Dec 19, 2014 | 01:31 PM
Levine's Avatar
I did clean the MAF sensor that goes into the throttle body. I am guessing I should also clean the "butterfly" thingy. Is that right ?
Old Dec 19, 2014 | 01:39 PM
KdF's Avatar
KdF
I would take it off and do a complete cleaning with Throttle Body Cleaner. all thru the inside. Can't go wrong. Don't force anything tho.
Sep 24, 2015 08:15 PM
Airborne42
Sep 24, 2015 11:01 AM
samjluck
Sep 17, 2015 10:24 PM
