my V8 has a hiccup??
Old Sep 2, 2008 | 12:41 AM
jason929's Avatar
Its always done it but seems to be happening more and more. I'll downshift or start from a stop and i'll lose all power for a split second. Although i have a C&L intake, i do believe it did it before the purchase of this. If i bring it to the dealer, i hope they don't blame it on the intake.
Old Sep 2, 2008 | 12:45 AM
Deric's Avatar
Check for any leaks around the intake or any other hoses. Dealer would probably blame the mods if they find a problem under the hood.
Old Sep 2, 2008 | 05:37 AM
tw0scoops123's Avatar
Is it after a long cruise? 20 minutes or more at a constant speed? Could be your fuel pumps...there is a TSB out there for it.
Old Sep 2, 2008 | 06:22 AM
poldrv's Avatar
Put a bottle of Chevron Techron in your tank on the next fill it should help to eliminate the problem.
Old Sep 2, 2008 | 10:59 AM
woody24's Avatar
ive had the same problem. Its an automatic. For me it would sometimes happen on the way to work. But would always happen at the same stop light. It was a 55min drive on the interstate, and as soon as I get off and stop at the light, it would pause for a second before going anywhere. But always made me feel like an idiot because once it kicked back in, it would jump. Like I wasn't a good manual driver.
I bought some Seafoam thinking it was something with the fuel. But I don't work there anymore, and my drive is completely different. But figured it was something to do with cruising for a while at the same speed.
Old Sep 2, 2008 | 11:25 AM
adrenalin's Avatar
Yours is the fuel pump. I have the same issue and sure enough, the fuel pump is the problem.
Old Sep 2, 2008 | 12:35 PM
woody24's Avatar
so whats the fix for it? The car should be under warranty still. Would this be covered? Might as well get this and the fuel fillup problem looked at.
Old Sep 2, 2008 | 02:21 PM
jason929's Avatar
yes it is after a long cruise, always happens on the highway or as soon as i get off the highway. So is the fuel pump bad?
Old Sep 4, 2008 | 05:58 AM
adrenalin's Avatar
There is a TSB out for the fuel pump issue. You should just be able to explain the issue to the dealer and have the pump replaced under warranty.
adrenalin's Avatar
Yes, the fuel pump in your car should be replaced.
Old Sep 4, 2008 | 10:08 AM
woody24's Avatar
Ok, so I admit that I'm not hip with all the lingo for cars. I thought TSB was a part that goes onto the fuel pump. But reading into context, I figured it was some sort of recall notice. So I looked up what TSB stood for. And found that it stand for "Technical Service Bulletin". Is this another name for a recall? Or a downgrade for a recall? Like its not life-threating, but is a problem that needs fixed.
IS there any documentation for this problem, so I can go to them, and tell them exactly what the problem is. And not have to enplane the whole story of what happens, and then they have to see if there is a TSB?
Old Sep 4, 2008 | 10:33 AM
mot250's Avatar
Check out the Technical Service Bulletins on this site in the Waurantee and service section.
TSBs are not recalls but tech instructions for common problems. You need to review TSB 06-09-09 Hesitation on Acceleration. I had mine taken care of. The fuel pump diaphragm on some fuel pumps leak/lose pressure, causing the symptoms you are describing after long drives at a constant speed.
I quoted the TSB number and left a copy of it in the car when I dropped it off at the dealer. Occasionally, some dealer service managers will want to verify the symptoms but for this problem, it would require more drive time than would be customary so you may have to explain more about the symptoms your car has than let them figure it out on their own by driving it. Make sure the techs will do the replacement by accessing the pump from under the rear seat (as opposed to dropping the tank). The dropping the tank method has occasionally caused returns to the dealer for vibration issues for not clocking the driveshaft properly upon re-assembly.
This link should take you right to the appropriate TSB...
http://bradbarnett.net/mustangs/gala...hesonaccel.pdf
Old Sep 4, 2008 | 06:56 PM
Donna's Avatar
Queen Of Nascar
Yep, my car did this too until I got the fuel pump changed. No problems since.
Here's the TSB:
File Type: pdf
Old Sep 4, 2008 | 07:16 PM
officespace56's Avatar
+1 It has happened to me before also. I was on a 2 hour drive with cruise control and about an hour and a half thru I downshifted and it "hiccuped" but it went away after i turned the cuise off
Old Sep 4, 2008 | 07:18 PM
And I need to get this fixed! I have LT's and a CAI, so I am guessing this will be a problem at the dealer huh?
Old Sep 4, 2008 | 08:28 PM
Donna's Avatar
Queen Of Nascar
I guess it depends on your dealer. I have a CAI and didn't have any problems.
Mustang259
'10-14 Interior and Audio
74
Mar 25, 2016 04:27 PM
friedmaster
05-09 Interior and Audio Mods
Apr 10, 2015 07:39 PM
Sanders92
Sep 2, 2014 08:28 PM
rmurer
Jun 9, 2014 12:18 PM
2006GT500
Jun 19, 2006 07:04 PM
