My doors don't lock?
Old Apr 10, 2005 | 06:26 AM
robynspony's Avatar
Hey, locked my car last night and went to get in this morning (forgetting I locked it). The doors open and alarm comes on. What's up with that?? How do you lock the doors? I used the remote tried both one then two and still doesn't work. Anyone have this problem?
Old Apr 10, 2005 | 06:33 AM
StangNut's Avatar
Sounds like the remotes need to be reprogrammed. Only the dealer can do it, I think.
Old Apr 10, 2005 | 06:38 AM
05WindveilGT's Avatar
Or a sensor in the car.
Matt
Old Apr 10, 2005 | 08:37 AM
frdtch05gt's Avatar
If neither remote for the car works, there's a programming procedure in the owners manual. Turn the key to "on" 8 times within 10 seconds, ending with the key in the "on" position. The locks will cycle down and up to indicate programming mode, push a button on each remote, turn key off. The locks will cycle each time you push a remote button to indicate sucessful programming, then cycle again when you turn the key off to indicate programming mode end. Give that a try first, maybe they forgot to program the remotes at the factory.
Old Apr 11, 2005 | 11:36 AM
robynspony's Avatar
Thanks everyone, I found the culprit! I bought these Bullitt door locks for the car and they don't go down all the way. Just took the trim peice off and made the hole a tad bigger and now my car locks!
Old Apr 11, 2005 | 11:57 AM
kevinv-6's Avatar
OOOOPPPSSSSS!!! hella-uncool. Did you get UPR pins? I got mine on saturday and they fit perfect, at first the drivers side door didnt, but thats cause I screwed it on at an angle.
I thought I would be smart and took off the little piece that is around the pin. Snapped it off, twisted off the stock door lock, screwed on the "bullit" pins, went to put the piece and DOH! what do you know it didnt fit so I had to unscrew the piece again and put the piece back in then rescrew the pin.
Old Apr 11, 2005 | 12:03 PM
robynspony's Avatar
[attachmentid=17532]
I got mine from Crossroadz.
It was the first thing I put on the car, forgot all about it till I opened the door and it was supposed to be locked! They looked like they went down when you lock it but they don't go down far enough.
Old Apr 11, 2005 | 12:06 PM
kevinv-6's Avatar
Hella-Cool!! They look great!
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
