my 2006 mustang gt automatic
Old Jul 3, 2015 | 07:33 PM
robdog805's Avatar
My mustang gt automatic transmission is popping when i punch it hard
Old Jul 3, 2015 | 10:13 PM
houtex's Avatar
Um... congratulations?
Kind of an odd first post there, but hey, no problem. Welcome to the forums!
Popping could be a whole slew of things, so unless you know how to look for and repair them, perhaps it's best to take it to a shop and have it looked at.
The things off the top of my head are: Loose/bad transmission mount, bad CV joint(s) in the drive shaft, yoke issues either end, flywheel issue of some sort, bent something or another, internal transmission issues...
Need more info, but again, this might be better taken up with some experts, like a dealership.
Old Jul 4, 2015 | 12:04 PM
robdog805's Avatar
mustang
Ok its none of that It's popping through the mufflers
Old Jul 4, 2015 | 12:07 PM
robdog805's Avatar
Changed the fuel filter air filter still doing when i cruise its fine runs great
Old Jul 4, 2015 | 12:32 PM
houtex's Avatar
Wait, I misread your last post. Will revisit this in a little bit.
Edit: back.
So... There's several causes of this. Could be somewhat normal, in that back pressure relief and fuel cut off as the throttle is closed is one cause.
Too much unburnt fuel in the exhaust is another, although at WOT acceleration, sometimes that might happen.
Bent/stuck valves is a third, but I'm guessin' it's not that.
Bad timing is possible, but again... probably not.
If it's a leaky injector, you'd probably get an engine code on that. Have you had the codes pulled?
Have you done any exhaust changes? Sometimes different exhausts (see the back pressure thing) will cause that to sound louder, but it's normal.
Probably need an audio or a video of the symptom to try any further, but I'd say maybe you need to go to a shop if it's worrisome.
PonyShow
V6
Nov 17, 2017 02:00 PM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
iiizman
Jul 20, 2015 11:33 AM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
Coyote5-0
Jul 17, 2015 03:47 PM
