My 05 Needs major wiring fixing
Old May 26, 2021 | 01:07 PM
redheadmullit's Avatar
Exclamation My 05 Needs major wiring fixing
Hey People! I just bought a GT and it needs a lot of wire work. idk were to start or what good wires or whats bad wires can anybody help out on were I should go to get the info? Ik there is a wiring book on the model im ganna get it but ik im to dumb to understand a-lot of those diagrams. So mabea someone on you tube you know? I went into a place and they said it would cost hundreds of dollars. im a 21 year old in school i don't have that kind of dough, but what i do have a lots of is time! Thank y'all for reading and mabea helping!
Sincerly,
redheadmullit
Old May 26, 2021 | 02:44 PM
Jaryd21's Avatar
Honestly if you have the time you say get the book and a multimeter and go through each wiring diagram and see what they are supposed to be reading and test them. I have a little OCD when it comes to things and if I were in your situation that's what I would do. And yes there are probably are videos also that you can watch. But you have to watch the ones that you are trying to check for. Also the Haynes repair manual will only give you diagrams not the actual ohms and voltage and things like that
Old May 30, 2021 | 04:20 AM
shaneyusa's Avatar
Might post the problems your are having with the car. Unless you are planning on doing a complete restore I would try to fix what is not working first.
Did find this out there that might be helpful...
https://iihs.net/fsm/?d=1
Check the side panel under wiring diagrams.
Old May 30, 2021 | 12:17 PM
houtex's Avatar
^ This.
But also, Welcome to the forums!
Not only would knowing what issues you're facing be helpful, the reality is... maybe it's a bit easier to just buy the harness(es) in question so you can literally plug and play the car back to working order. You can go to a pick-a-part (or whatever you call it) and acquire one that way, or you can find one on ebay... lots of possiblities. The desire to repair the harness is admirable, but perhaps you can explore the cost of just getting it at the boneyard anyway and then decide what's best for you.
Hope that helps and good luck!
Flaming_Maniac
'10-14 Interior and Audio
May 20, 2014 12:48 PM
drumr90
May 20, 2012 02:37 PM
Dougxox
Sep 26, 2010 11:05 AM
diskojerk
Jan 11, 2007 12:13 PM
canuck power
Oct 6, 2006 07:46 PM
