Mustang drivetrain loss (flywheel vs rwhp) = 12.2% for manual?
Well, OK, I see your point, but someone who dynos cars every day and has been doing for several years seems like 'doing testing' to me. I originally asked him if the average losses on a manual transmission were about 15% and he said that it was closer to 12. He's done a Shelby 500 and numerous Vipers, plus several hundred others (all captured on the wall, with numbers). The S197 is no different to anything else. Averaged out over the years, with the numbers on the dynos compared to the manufacturer's claims, he's settled on 12%. Sure dyno readings vary a lot depending on a lot of parameters, as do outputs of nominally identical engines, but the mean value of a large sample gives you a 'test result' to work with. Or at least an informed observation. And that observation leads me to believe the GT is a little conservatively rated, which is a good thing.
As you know, that would involve removing the engine, running it and testing it on stands, refitting it, then running it on the rollers, on the same day or at least in similar conditions. So no, not many people do that. His method, as I explained, is comparing stock dyno numbers to manufacturer's (engine output) figures over a large sample. Knowing that manufacturer's figures vary, and engines vary and accounting for that in the large sample's mean is the best anyone can do without the exhaustive process outlined above. Tillmanspeed's 16% and the suggested 12% differ by 12hp on the 300hp GT. 252 vs 264 if 300 is correct. A lot of s197s are showing 10-15hp above even the 264, which suggests the engine output is well underrated (5%) but within tolerances. If the 16% figure is closer to the truth, then the margin of underrating is close to 10% of total output, which seem to be wild engineering tolerances. I don't care either way, but 12%, given the evidence, seems more realistic than 16%.
The OEM would know the actual factor due to the amount of testing they have conducted. Like I suggested earlier in this thread, the only surefire way that I know to determine this value is to run the engine on an engine dyno, then drop that motor into a S197 GT and run that on a chassis dyno. Until someone does this or has the data to back it up, 12% is still speculation and far from "confirming" the actual factor.
Like I said before, the 2000 Ford Crown Victoria was advertised to have 215 hp. Those "in the know" knew about Ford using retarded timing, and only achieving roughly 160 rwhp on the chassis dyno. The drivetrain loss factor was already known, so Ford over-rated the advertised hp by 28 horsepower!
I'm not saying that 12% is the wrong factor, but I am saying that the method used to derive this figure (thus far in this thread) isn't solid.
The Crown Vic example is messed up because of the supposed ignition retardation. We have no actual motor output number to work with.
I say the 12% is observed from repeated experiment, given the physics associated with engineering tolerances, making a claimed engine output figure +/- 5% (at most) away from any individual motor's actual output at the crank (which makes it a soft constant). Plus, we have observed rwhp data that supports the theory. So it's far from speculation, in my view, it's observation.
The 98-99 Crown Vic is identical to the 00 Crown Vic. It was shown repeatedly that the 98-99 Crown Vics will dyno 180-183 rwhp, and it was known that the drivetrain loss is slightly under 15% (through OEM conducted tests). Almost everything is known. The 00 Crown Vic is just an example of how the advertised horsepower can be completely wrong. Had someone used that advertised figure as a baseline, they would have assumed a loss factor of around 25% (incorrect for Panther 4R70W w/ TC locked in 3rd gear).
AFBlue and your dyno operator are guesstimating the losses using the advertised horsepower as a baseline. You can sit there and run 30,000 chassis dyno tests and still not come out with the right answer because you haven't isolated the engine from the drivetrain.
As opposed to your dyno operator's repeated experiments dealing with RWHP and not engine output?
You can quote a thousand crown vic examples to me, but you already stated that something else was changed between supplying that number and the actual testing, i.e. the ignition remap. You are right, the pure scientific experiment you suggest would be the only sure fire way of knowing for certain, but it's unreasonable in the real world. I'm happy with the manufacturer's numbers plus dyno testing for my purposes - YMMV.
To get back to the OP's interesting point, in my opinion, a mean of a small sample giving you a value within 2% (306) of the supplied number of 300 is remarkable but only because it doesn't vary as much as I would expect. As you know, mine is also in that range at 276hp, at 12% that's 309 at the crank, that's only 3.5% out. Where are the dynos with manual GT stockers only putting out 265, which is 3.5% the WRONG way... 'Friday afternoon' engines?
319 for the Shelby may be an indication that during testing, they couldn't quite average out a 20 with the 'sports' tune (which has its own variables on top), so gave the actual tested mean number instead of the original guesstimate 325. Rounding down not acceptable anyway for other reasons.
That's probably why Ford go conservative on the Mustang rating, to allow more headroom for SE/tuner stuff.
The standard rule of thumb was 15% for manuals and 25% for automatics. Needless to say, they've improved on automatics with the lock-up torque converter.
It's more than a guess, it's the manufacturer's supplied number. Ford are not guessing. There are variations, but these are within close parameters.
Surefire way to answer the question or find out the drivetrain loss:
Use engine dyno to determine engine output
Plop that motor into a S197 GT (stock drivetrain, stock suspension)
Run that vehicle on a chassis dyno
Use arithmetic
It'll be much closer than using under/over-rated advertised engine outputs or Swiss dyno operator guesstimates.
It doesn't make sense to me, if you consider two different motors that use the same drivetrain.
For example, replace your 300HP motor with a 400HP motor, and your drivetrain remains the same, assuming %25 loss (automatic trans), then your calculated drivetrain loss would go from 75HP to 100HP.
I'm not saying you're wrong, i'm only saying I don't undertand it. Please explain it me.
25% for the Automatics? So, if I dyno's at say 285 HP with mods of course, I would be over 350 at the Flywheel? That is hard to believe.
That was an OLD rule of thumb, probably derived before widespread use of a lock up converter (or the dyno operator simply didn't bother to make sure the converter was locked up in the 1:1 gear ratio). Again, you can't go by these estimates because the 4R70W (a 4-speed auto used on the 99-04 GT and 96-up Crown Vic) demonstrated much less parasitic drag than 25%, mainly due to the use of a lock-up torque converter. The manual transmission still relies on a clutch so it can't be too far off from the 15% estimate.
Thanks. But I do like the sound of 350+ HP. LOL. This has been an interesting thread and I learned a lot. Thanks guys!
In pondering this a little more, It occurred to me that if you take the "lowest"
number a Manual GT has dynoed, (Out of the examples given earlier 258 was the lowest) that car has to make 300 hp flywheel, else Ford is open to another fiasco like the 99 or whatever Mustang it was that didnt make advertised hp and wound up in some kind of litigation.
258 if I did the math right would be a 14% drivetrain loss and 300 fw hp.
275 which was the highest example you listed at 14 % loss from fw to rwhp would come in around 338 fw hp.
Sounds a little high but consider this also.
Every Manual GT wont have the exact drivetrain loss due to the same considerations that apply to the Motor. Variables in assembly tolerances, bearing variances, rear gear specs etc etc etc......
Seems to me this whole thing of % of loss hp from fw to rw hp is a dog you could chase for ever.
Why is drivetrain loss given as a percentage of the flywheel HP rather than just a flat number?
http://www.f150online.com/forums/sho...6&postcount=13
...So now what about driveline % losses vs driveline HP losses?
A 1999-2000 Lighting making it's 360 SAE Net rating generally puts down about 290 RWHP on a good eddy-current dyno, representing a 19.44% loss (70/360=19.44%). However, take a "regular" F-150 with the 260 HP normally aspirated 5.4 motor with a 4R100 (admittedly a rare configuration), and we see once again, about a 70 HP loss - but now that same approximately 70 HP loss represents almost a 27% driveline loss (5.4 2V normally aspirated from 1999-2003 making 260 HP, 100 less than a Lightning - so 70/260=26.92%).
Or take the 1999-2003 4R70W automatic F-150's, for example - in a 5.4 2WD, we generally see about a 65 HP loss, which represents a nice round 25% loss for the PI 260 HP 1999-2003 5.4 2V's - but if it's a 1999 220 Hp 4.6, the HP loss is roughly the same, so now the *percentage* driveline loss represents a whopping 29.54% - or in a 2001 & up 231 HP 4.6, it represents a 28.14% loss.
Now in the manual-tranny vehicles, the 5 & 6-speed manuals tend to lose (in round numbers) about half as much power as the automatics do - so a typical 220 HP non-PI 4.6 5-spd. 1997-1999 F-150 sees about 185 RWHP in stock trim on an ideally-running stock truck, just for example (though we've seen a number of them hit only 170-175 stock). So now we're talking about a 15.91% loss. But drop a 5.4 260 HP motor in that same truck as a number of our customers have done so that they can have a 5.4 manual-tranny F-150 (which Ford doesn't make), and the driveline loss stays close to 35 HP (it might hit 38-40 HP), which then represents a 13.46% loss.
driveline losses are NOT always the same % - we see that all else being equal, the amount of power in terms of a % that is lost to the driveline with otherwise identical drivetrain hardware can sometimes vary significantly, even though the HP loss may be about the same.
Using the manual F150 with the 4.6L or 5.4L, they both lost 35 horsepower going through the drive train to the wheels.
So on a Manual Mustang GT, if we assume that 271 rwhp is the average rwhp (avg I got for 20 TMS stock manual GTs), and it has the same drivetrain loss as the Shelby GT (39), then we get 310 at the crank.
So IMHO it wouldn't surprise me if the GT is underrated, the shelby GT is making slightly more than the GT at the crank, but Ford decided to keep a safety blanket and advertise lower than actual output to cover their a$$.
You are beating a dead horse. Go and do the experiment if you feel so strongly about it. The nationality of my mechanic is irrelevant. In my opinion, you are being a bit of a **** for reasons only known to yourself.
Hi, The x pipe is part of the mods, its probably hidden in the power pak. The hp on the car is the same as the GT-H, the problem is when we EPA tested it came out lower, so we are not sure if the test was different, or the GT-H was 319 too even though we were told 325. we ran it again it was 320, so we are saying 319, but with the other upgrades and the bigger rear, it
certainly feels like more
So I think it's safe to say that the flywheel hp is confirmed by the EPA to be 319 or 320 hp. If folks are averaging 280rwhp on a dynojet (seen SGT dyno results: 1 was 279rwhp and the other was 281) then that is a confirmed 39-40 hp loss through the drive train (the same as on the Mustang GT).
So based on the info I posted in post #57 of the this thread, I believe you simply add 40hp to your SAE corrected dyno HP to get your flywheel hp.
Or for those who are not convinced by post #57 and still want to use a percentage, then that would be a 12.2% drivetrain loss.
ssjbuu
Aug 28, 2015 08:55 AM
