Trick question concerning headlights.
Old May 24, 2007 | 09:31 PM
347strokin's Avatar
I've been a long time fan of this site but never contributed. I've got an 07 black GT on 20's and a 500hp 88 GT. Anyways:
I've purchased the agent47 ram air kit which moves your headlights to approximately where your fog lamps were. (fog lamps are deleted)
http://agentfortyseven.com/other_pro...air_other.html
Now I would love to be able to either disable my Daytime running lights or be able to turn my headlights off and on with maybe the old fog lamp pull switch?
Maybe I could just switch a few wires from the fog lamps and put them on the head lights so I can control when they are on and off?
Old May 25, 2007 | 08:00 AM
spike's Avatar
I'm confused... You have daytime running lights? I didn't know any S197s had stock daytime running lights. But if you do, I don't see any reason you couldn't switch the wires that were originally for the fogs.
That's a pretty neat kit though, I've haven't seen that one before.
Old May 25, 2007 | 08:15 AM
spike's Avatar
A quick search turned up two other options (although your first one still seems like it will work):
1) Apparently the S197s have DRL capability but they are usually disabled for most of the US and enabled in Canada. Are you in Canada? One solution is to find a dealer that will disable them for you. (I'd be curious to know if you could find a dealer willing to do that)
2) another option is to get these DRLs that use the bright element of your front blinkers. http://www.webelectricproducts.com/products.htm
Although this still requires that you disable your current DRLs.
Old May 25, 2007 | 08:28 AM
kevinb120's Avatar
I don't know anything about the DRL's, but the kit looks cool
Old May 25, 2007 | 08:38 AM
F150ATM's Avatar
You are aware that kit is for "off road use" only and therefore not street legal.
Something to consider before you spend the $$.
Mike
Old May 25, 2007 | 11:53 AM
kevinb120's Avatar
If you had high/low beams in the fog area and no non-working lights in the scoop area, would they really be illegal?
Old May 25, 2007 | 07:19 PM
347strokin's Avatar
I do live in Canada and have the DRL's.
I know the kit is illegal for street use but I couldn't find any laws or rules saying why.
I plan on using some super bright bulbs so I still have decent lighting at night but I just don't think the kit will look as good with the lights on full time during the day.
Old May 25, 2007 | 08:30 PM
DarkFireGT's Avatar
The reason that they're illegal is that they're too close together. Headlights have to be a certain distance apart. I've accidentally ran with my fogs only several times and cops haven't pulled me over, but that's not to say that they wouldn't.
Old May 25, 2007 | 09:07 PM
karman's Avatar
State of NH:
Saf-C 3217.03 Lamp Function. A vehicle shall be rejected if:
(b) Any bulb, sealed beam unit, lamp or reflector does not meet manufacturer's specifications or violates federal motor vehicle safety standards.
(l) Replacement lamps or component parts shall be comparable to the manufacturer's original equipment.
Most states have similar rules.
Old May 25, 2007 | 09:27 PM
347strokin's Avatar
I'm willing to risk it. I've already bought the kit so if I get busted too many times I'll just have to sell it for pennies on the dollar...
Old May 25, 2007 | 09:31 PM
karman's Avatar
To boldly go...
As long as you know the risk, you make the choice.
Old May 26, 2007 | 07:41 PM
DynamicmustangGT's Avatar
I thought I was too live free or die in NH? So I can't kill myself with these lights if I want?
Old May 27, 2007 | 10:22 AM
347strokin's Avatar
It's not that bad, there's still marker lights on every corner of the car.
Old May 27, 2007 | 05:53 PM
karman's Avatar
No, you need a motorcycle for that (no helmet law).
Old May 27, 2007 | 09:42 PM
Isn;t the seatbelt law over 18 you don't need one either? Been a while but my bro lives there
Old May 28, 2007 | 07:48 AM
karman's Avatar
True.
Personally I think it is a lot easier to die on a bike without a helmet than a car without a seatbelt.
I always wear my belt in the car and a helmet on a bike no matter what the law lets you do.
Old May 29, 2007 | 05:22 AM
Robbieg's Avatar
Originally Posted by karman
True.
+1....Me too, but even though I always wear my helmet and my seat belt I feel like it should be my choice.
Old May 29, 2007 | 05:28 AM
Robbieg's Avatar
I don't think you will have any problems, I don't know how it is in Canada but I think if it were here in FL were I live you would not get any hassles. I would probably be more worried about turning off DRL's (by the way I have always been against DRL's as many people who ride motorcycles are) if they are required because it would be much more obvious that no lights were on than were they were mounted.
Old May 29, 2007 | 09:32 AM
F150ATM's Avatar
Just curious, why would anyone be against DRL's? I find vehicles much easier to see if they have their lights on. Just curious about that point.
Mike
Old May 29, 2007 | 09:56 AM
Robbieg's Avatar
Mike
Because it takes away from those of us on motorcycles, if everything on the road has it's lights on then you get use to it and don't even notice it, when it's just motorcycles with there light on you stand out thereby being notice and not run over or pulled out in front of. This is especially true in city traffic.
