Must Read guys
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by CancerBoi69
Can I take my body off my v6 n put it on the frame of a v8 or would it be easier to just swap the motor, trans driveshaft and rear end onto my v6
In all honesty is is much more effielcient to just buy a v8 Stang. Your gonna spend more than its worth doing the swap.
Why not just form the body out of resin and fiberglass? It would probably cost a bit less but the again it would probably blow off as soon as you took it down the freeway..
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
A Man Just Needs Some....
OP. the engine is supported by a "cradle" framework support bolted under the front end of your car. That entire assembly can be dropped with the engine and trans and swapped on to your car. If that's what you meant. Bone, take it easy, some people don't do this for a living.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by AlsCobra
OP. the engine is supported by a "cradle" framework support bolted under the front end of your car. That entire assembly can be dropped with the engine and trans and swapped on to your car. If that's what you meant. Bone, take it easy, some people don't do this for a living. ![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
![Stickpoke](https://themustangsource.com/forums/images/smilies/stickpoke.gif)
I just want more speed lol and the v6 doesn't gain all that much after upgrading parts. I really want came but can't find none anywhere. Could someone help with that
Why don't you boost it? You can run a supercharger or turbo for less cost potentially than going up to a full blown GT..
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
