Moroso Power Steering Tank Fluid Levels?
For you that have installed the Moroso Power Steering aluminum tank. How much fluid did you use to fill it up, since there is no way to tell the fluid levels like the factory plastic unit?
I installed mine last night and put in new fluid up to about half to 3/4 an inch from the top. Not sure if that was too much or not enough.
Sean
Sean
Rando
Aug 25, 2021 11:12 AM
