location of flasher module?
does anyone know where the flasher module for the taillights is located in the mustang? i need to replace it to make my LED sequentials work properly
thanks
thanks
its the APC LED taillights with the webelectric sequentials
the problem is..the inner lamp on each side only has the dim light and not the brighter..push the brake pedal brighter mode..and that randomly the others flash real quick
will a load equilizer solve both of these issues?
do those taillight assemblies allow the inner lamp to function on both modes?
reason i ask is because the LED lamps have the following. 3 wires on the connectors for the 2 outside lamps and 2 wires on the connector for the inside
will the webelectric still make the one with 2 wires act as a brake lamp too?
