Kenne Bell installed. Does yours compare?
Old Oct 24, 2007 | 07:16 PM
ashfope's Avatar
Finishes my Kenne Bell 2.6 install last weekend. Evrything went extremely well. Have driven it around for tests and everything seems to be fantastic! Only thing that gives me a little concern is that the factory temp gauhge stays in the middle and I don't see a huge drop in coolant level from the resevoir. The top heater hoses are hot but the bottom one is cool to the touch. I had it out for at least 40 minutes tonight. The air temps are around 70. Does everyone have the same experience with the kenne Bell's that are intercooled? I have taken the thermostat back out to double check that it was incorreclty and I also tested it via a pan of hot water and a temp gauge. Just checkin to see if others experiences are the same?
Old Oct 24, 2007 | 07:36 PM
Ric's Avatar
Ric
And a dyno plot might be nice too.
Old Oct 24, 2007 | 08:30 PM
RRRoamer's Avatar
ashfope,
If my memory is correct, the factory temp gauage will be in the normal range when ever the computer thinks the temp is normal. It does NOT give a linear 1:1 reading of the temp. So, instead of giving you a 120-240 degree range, it sort of only has cool:good:hot ranges. If you want to see the actual coolant temp, you are going to have to hook up your calibrator and datalog the temp data. Yes, it's a pain.
Of course, I could be wrong too...
Old Oct 24, 2007 | 08:36 PM
theedge67's Avatar
You are right!! Once the temps reach around 180, the gauge will read normal and not budge until they get over a certain amount...like 230 or something. So from 180-230 the gauge reads the same.
May 3, 2026 05:42 AM
CiniZter
25
Apr 28, 2016 05:41 PM
50Cal
Sep 17, 2015 06:43 PM
Sep 8, 2015 10:45 AM
