Keeping engine & compartment clean
Hey All,
What's a good product to use for kepping the engine & compartment really clean.I don't show the car but I like show quality.What do you use to keep the black stuff black and everything else clean???
Thanx,
Jack
Thanx,
Jack
I hate dressings on rubber so I use a rag and quick detailer, keeps it looking 'naturally' new and can be used on anything. The design of these cars keeps the engine bay cleaner then anything I have ever seen before. The old generation got filthy in a week.
For years, I've taken many vehicles down to the local do-it-yourself spray booth, and blasted everything I could get at with the high-pressure rinse. Drove the vehicle home, lifted the hood and all I needed was a towel to dry off what little water remained. I do this every spring on anything that has seen winter. Results are like straight out of the factory, and I've never had any issues because of it.
For years, I've taken many vehicles down to the local do-it-yourself spray booth, and blasted everything I could get at with the high-pressure rinse. Drove the vehicle home, lifted the hood and all I needed was a towel to dry off what little water remained. I do this every spring on anything that has seen winter. Results are like straight out of the factory, and I've never had any issues because of it.![Headbang](https://themustangsource.com/forums/images/smilies/headbang.gif)
I do the same with all of my vehicles. I usually put plastic bags over the battery, alternator, and intake filter (if the car has an aftermarket unit). Then I sprits it down and spray some Black Magic tire foam on it. I usually let the tire foam sit for a few minutes before wiping it down with a damp chamois or cloth. Looks great and the tire foam makes the hoses look nice.
I just use a super soft scrub brush and car soap to knock off the road dust. Then rinse it all down with a garden hose w/o sprayer. Quick detailer does a bang up job as well to keep the black bits looking new.
Be careful using Simple Green on aluminum as it will corrode if not fully removed.
sarnold58
6/9/19 02:22 PM
BavarianStang
9/5/15 05:55 AM
