Just finished installing HID kits from stangmods!!
Okay people, I just finished installing the HID kits from stangmods and they look absolutely terriffic, I have only one complaint however. On the headlight kit harness when the vehicle is running, there is a distinct buzzing sound coming from the two relays that are bundled together... Maybe its just me but I don't think that is normal... Its quiet as a mouse with the headlights on and the engine off. And it isn't audible from inside the car, only from the exterior.. I'm kind of stumped here, anyone have any thoughts??
and also, do you have any shots of the wires under the hood? it would be a great help for install
Its the 6000k temp, bi-xenon bulbs kit. Hi and low beams on the same bulb. Here is a picture of a similar harness I found on the net...
The relay is where the buzzing is coming from, not the ballast. I actually touched the relays and there seemed to be quite a bit of internal vibration.
Mine did too when new, but I think they've quieted down now (or I'm used to it). Relays buzzing isn't necessarily an issue. If they chatter that's another story. Chattering is caused by insufficient coil voltage which in this application would likely be caused by undersized wire. Give them a few days.
The VVME kits now include a solid state relay module. I couldn't figure out what it was until I looked at how it was wired. They no longer use a Bosch-style mechanical relay.
Kevin, did your VVME kit include two 20A fuse holders? Were they weather-proof/resistance or were they exposed?
Diode Dynamics
6/12/18 03:26 PM
Diode Dynamics
2/28/18 09:37 AM
