Jack slipped and my car hit the ground
Old Sep 10, 2006 | 07:13 PM
King Taco's Avatar
Angry Jack slipped and my car hit the ground
I wuz trying to put my spare on and while my car was
elevated by the jack, the jack started bending and
slipped and my car hit the ground, so it was resting on
rota and some other thing which i can't name. do u
the suspension is messed up??????? this was the rear
right tire btw. pls help!!!
Old Sep 10, 2006 | 07:22 PM
2005GTDELUXE's Avatar
bmp ....I have never had that happen , just make sure theres no damage and the car is safe with the brakes
Old Sep 10, 2006 | 07:43 PM
rocket88's Avatar
make sure the surface and edges of the rotor were not damaged, otherwise I'd say you're ok. I've had it happen, not on my mustang, but it didn't hurt anything. What kind of jack were you using? I'd also make sure that there is no damage where the jack was, if it got pinnned between the ground and the car.
Old Sep 10, 2006 | 07:51 PM
05GT-O.C.D.'s Avatar
I lust for a M24
What jack did that happen with?
Old Sep 10, 2006 | 08:07 PM
King Taco's Avatar
It was the jack that the came w/ the car...but i realized just now my ebrake wasn't fully up as well...also something got bent really bad, the thing that is used to hook the car to a tow truck/flat bed. i am worried about the alignment now.
Old Sep 10, 2006 | 08:55 PM
mbkintner's Avatar
So did the jack actually bend or did the car slip off the jack since the e-brake wasn't fully engaged? What were you using for a jack point? You may have to post some pictures to get good feedback.
Old Sep 10, 2006 | 09:00 PM
King Taco's Avatar
The jack doesn't appear permanently warped or anything... i believe ur right, and used a bad jack point.. basically after several minutes of being elevated
the car shifted backward and then wham!
Old Sep 10, 2006 | 09:12 PM
cop on my back's Avatar
You will have bent the rotor dust shield for sure. Actually, does the rear have that? I cannot see the suspension bending, just not enough force invovled. Rotor damaged, yup, I would say it could be.
Old Sep 10, 2006 | 09:46 PM
No dust shield.
Old Sep 10, 2006 | 10:07 PM
King Taco's Avatar
****. welp, ill have it looked at i guess and tell you guys wut the mechanic says :/ thanx for your insights.
Old Sep 11, 2006 | 10:24 AM
rhumb's Avatar
Man, not to get too preachy, but if all that happened were a few bent pieces, consider yourself lucky as you seemed to have committed a litany of what not to do when jacking your car up.
Suggestions:
Should use trunk jack for on-road emergencies. Use a proper floor jack for maintainence and modding.
Always use jack stands of some sort.
Triple check that your brakes are properly set.
Chock the wheels so the car can't move regardless of the brakes.
Make sure you're on level ground so the car doesn't shift.
You are lucky you weren't changing to oil or something or that bent piece would have been your skull. I'm glad you're all right as the car can always be fixed up.
Old Sep 11, 2006 | 10:51 AM
06GTwJUICE's Avatar
when i'm jacking a car up.. once it's where i want it... I toss the tire i'm taking off under the frame of the car just in front of (if the rear) the wheel well.. this way if the car slides off the stands or jack while i'm under it.. i have a nice rim and tire to hold the car up.. rims = cheap
just be happy the car didn't land on your legs
Old Sep 11, 2006 | 12:10 PM
RaGsHoCkEy88's Avatar
yea man thank god ur ok...i had my car slip off ramps while i was driving them up the ramps and i destroyed the ramp, luckily i had a nearby jack to jack it up (at the right point) and slip the ramp out. no damage at all. but the way that thing came down, its not gonna have any mercey on anyone, sooo just be happy u werent under it.
i suggest using proper equipment
Old Sep 11, 2006 | 08:38 PM
mbkintner's Avatar
Were you using Rhino Ramps? I bought some to use during oil changes. They seem to be strong but I still feel a little uncomfortable under the car. I use jackstands underneath the car when on the ramps but I doubt the stands would hold up to the weight of the car crashing down on them while shift sideways or forwards.
RRRoamer
Jan 19, 2017 05:27 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
71BlueStang
Jul 31, 2015 01:08 PM
roushcollection
Jul 28, 2015 02:08 PM
