issue with blow motor possibly?
Old Nov 2, 2010 | 10:56 AM
jcopin's Avatar
When i have the fan off air will still come through and more forcefully as i drive faster. at 70mph its almost the same speed air coming through as if the fan is on 2. if i select fan 1 and floor the air will stop coming through the upper vents.
do i need a new blower motor?
any idea would be great
thanks
Old Nov 2, 2010 | 01:38 PM
slidejob's Avatar
Originally Posted by jcopin
When i have the fan off air will still ocme through and more forcefully as i drive faster. at 70mph its almost the same speed air coming through as if the fan is on 2. if i select fan 1 and floor the air will stop coming through the upper vents.
do i need a new blow motor?
thanks
If I understand you correctly, you do not need a blower.
That is the normal control for the system. Once you put the mode switch on their is a very slow fan speed. If you listen carefully you can hear it running & fell it pushing air.
To totally turn off the system put it in the off mode. You will then see the fan will not operate at all no matter what position you put the fan switch on..
Old Nov 2, 2010 | 03:13 PM
jcopin's Avatar
no when i turn it OFF OFF air comes through whent he car is moving..the faster the car the faster the air comes in
any ideas?
Old Nov 2, 2010 | 04:18 PM
slidejob's Avatar
Is the air hot or cool?
Old Nov 2, 2010 | 07:10 PM
jcopin's Avatar
it depends..if i turn the **** to hot then its hot...cold then its whatever it is outside.
although if i come to a stop then absolutely nothing comes out
Old Nov 2, 2010 | 09:05 PM
slidejob's Avatar
Sounds like a control problem with the HVAC vent system. Your 1st post did say that if you turned to the floor the vent stopped blowing.
Do you have control at other positions?
If so then the system is not closing when you want it off.
Most cases it is a vacuum leak causing the loss of control.
Can you hear any high pitched whistle sound from the dash area or under the hood?
Old Nov 2, 2010 | 10:00 PM
jcopin's Avatar
if i switch it from OFF to floor it will stop coming out of the vent and come out of the floor.
would the high pitch whine increase with the rpm? i havent checked yet just want to know what i am listening for.
just to be clear the ac and heat controls work fine..its just when i turn it off that this happens
thanks
Old Nov 3, 2010 | 10:58 AM
05YellowGT's Avatar
Maybe the vent that closes when you push the recirculate button isn't closing when you turn the system completely off ? Try hitting the recirculate button to see what happens ...
Old Nov 3, 2010 | 12:12 PM
jcopin's Avatar
il check it out later and let you know
Old Nov 3, 2010 | 12:15 PM
chutoyy's Avatar
The vent area under the wipers will draw in air as you drive faster.
Old Nov 3, 2010 | 01:51 PM
jcopin's Avatar
but where is the vent door that opens and closes?
Old Nov 3, 2010 | 06:15 PM
slidejob's Avatar
In the dash.
Has the car ever been wreaked or had any dash work done?
Old Nov 4, 2010 | 08:55 AM
jcopin's Avatar
one time a old guy in atlantic city tapped my rear bumper and made a mark to which i freaked out in front of cesars palace.. that count?
Old Nov 4, 2010 | 10:38 AM
slidejob's Avatar
haha, no.
Last thought as it is very hard to diagnosis on the internet.
The cabin air filter is easy to access. It is behind the battery covered by a small panel with plastic clips. Pull the filter & see if you can diagnosis what is happening. I forget what is exactly behind the filter & how much room you have, but you may find the problem. You may also want to change the filter.
Old Nov 4, 2010 | 12:40 PM
jcopin's Avatar
i change the filter every 20k or so. il look more closely but if i remember correctly theres a screen behind it
Old Nov 4, 2010 | 01:05 PM
Wander's Avatar
From your description it really sounds like a door in the heating/AC system is not closing. If you turn the system off, there should be no air coming out anywhere, that's how mine works. That whole system is behind the dash. I haven't had to work on that kind of a problem for years, and older cars were much easier.
Old Nov 4, 2010 | 02:00 PM
jcopin's Avatar
thats what im thinking. anyone have a schematic of the hvac system for the mustang?
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
dbent15
Sep 5, 2015 12:15 PM
