Improvements
Old Mar 28, 2020 | 01:36 PM
Loganq90's Avatar
Improvements
Hello I am trying to see what people are doing to improve the power and fule efficiency of my mustang. Does any one have any suggestions
Old Mar 28, 2020 | 03:01 PM
SpectreH's Avatar
Power mods go from as simple as a cold air intake and tune, to complex things like turbos and superchargers. I don't think many have focused on economy.
Old Mar 29, 2020 | 07:57 PM
houtex's Avatar
Fuel efficiency... Run bigger diameter tires. Run 2.26 gears in the axle. Tape off all seams and put various wedges up front to better split the air, but be mindful of cooling issues. also, remove any wings/spoilers, but add a rear diffuser, that's actually a good thing. Don't use the A/C. Ever. But you have to also run with your windows up lest you add drag. And go read about 'hypermile', but be prepared to tick off your fellow drivers around you when you implement that.
If adding MPG is your goal, you should really invest in a better car for that than try to eek it out of a Mustang. V6 or GT. Because by the time you do all that and get it to actually work, you've really sort of made the Mustang not a Mustang, and it'll look ridiculous too with that wedging stuff. :P And you'll be seriously hot in the interior running no A/C and no windows down. And you'll not add power, so there's that too.
/I seriously want to see someone use the 2.26 gears. Quarter mile in, what, two days?
Ricedaddy
Nov 14, 2017 07:13 PM
bobj
Nov 9, 2011 10:08 AM
SuperSugeKnight
Mar 30, 2007 01:24 PM
12 Oz J
2007-2009 Shelby GT500
48
Jan 31, 2007 08:02 PM
