If True, An Impressive '05 Dyno
Old Sep 16, 2004 | 07:34 AM
Tony Alonso's Avatar
Thoughts on this post?
dynoed a yellow 05 today very impressive!!!! thing laid down 275 HP and 292 ft/lb all stock!!!! modifications will begin soon rumor has it that i can squeeze close to another 20hp out of her with my SCT tuning software.
Old Sep 16, 2004 | 07:42 AM
CatmanJJ's Avatar
Sounds pretty sweet to me.
Old Sep 16, 2004 | 07:44 AM
Galaxie's Avatar
I Have Admin Envy
Those are very nice power numbers if true...
shows the engine might be a little underrated, not as much as some expected
Old Sep 16, 2004 | 08:29 AM
joeuser42's Avatar
That would imply 343.75 hp at the crank using the rule of thumb %20 loss through the drivetrain. Sounds like at LOT underrated to me. I'm skeptical of this info, but that would be awesome.
Old Sep 16, 2004 | 08:31 AM
Madhouse's Avatar
You shouldn't have 20% drivetrain loss - should be more like 15% for a stick, 18% for an auto.
Old Sep 16, 2004 | 08:40 AM
maverick351ci's Avatar
its closer to 20 than you think your numbers are correct for the friction in the trannys but allso you have to consider rearend gear friction allso brake drag just my 2 cent worth but im hopeing that this info is true what post did that come from i must have missed it?
Old Sep 16, 2004 | 08:41 AM
Super Sonic Blue Mustang's Avatar
A yellow GT?????? if so 275 H.P. is not impressive, that is 25 less then Ford said it would put out I don't believe ford would get burned again on H.P. like they did with the 99 Cobra. check that dyno again. :scratch:
Old Sep 16, 2004 | 08:49 AM
CatmanJJ's Avatar
It's 275 hp to the rear wheels, which adds up to a decent amount more then the flywheel horsepower advertised by Ford, but I'm more interested in track times then dyno numbers right now, looks promising so far though.
Old Sep 16, 2004 | 08:50 AM
Super Sonic Blue Mustang,
That's the power rating at the rear wheels as opposed to the engine's crankshaft...the '03 and '04 Mach 1s have been dynoed in the neighborhood of 280hp and 300 ft-lb at the rear wheels.
Old Sep 16, 2004 | 08:51 AM
legendlimegt's Avatar
Blue,
The 275hp is a measurement taken at the rear wheels. The 300hp number from Ford is taken right off the motor. A 300 hp motor should only pull around 240-250 at the rear wheels.
Mike B)
Old Sep 16, 2004 | 08:52 AM
Ex-Contour Lover's Avatar
Education time:
The 300 H.P. rating is at the crank, not at the rear wheels. A dyno measures the horsepower at the rear wheels after experiencing losses due to the transmission, driveshaft and rear differential. ~18% loss is experienced via parts. So at the dyno 275 HP is equivalent to 335 HP at the crank. Ford could have said 335hp for this engine, but underated it by 35 HP or ~10%.
Old Sep 16, 2004 | 09:00 AM
Boomer's Avatar
So its about 15-20 hp underated
315-320hp
335-340hp
@ 15%
Sounds superflamtastic
Old Sep 16, 2004 | 09:01 AM
Ok OK no need to bombared me all at once I get it now lets just see what it does on the drag strip. Thanks guys for the tip I guess I miss interpreted the dyno theory.
Old Sep 16, 2004 | 09:03 AM
CatmanJJ's Avatar
Haha, it was like Tora Bora in her for a second when like 5 of us jumped ya.
I really can't wait to see these cars hit the streets.
Old Sep 16, 2004 | 09:04 AM
Must_stang's Avatar
Way to go FORD!!! :w00t:
Old Sep 16, 2004 | 09:06 AM
TennesseeMustangManiac's Avatar
I did not know that about the hp.
Old Sep 16, 2004 | 09:15 AM
joeuser42's Avatar
If you look at the corral posters previous posts, he looks legit. Hopefully he'll post the dyno sheet.
Old Sep 16, 2004 | 09:34 AM
trublustang03's Avatar
So based on the estimate that is putting out 275 RWHP and based on the weight, would anyone care to take a shot as to what kind of times we can expect out of this stang down the 1/4?
I say mid 13s for the 5 speed manual and high 13s for the 5 speed auto
Old Sep 16, 2004 | 09:53 AM
Dr Iven's Avatar
I used a simple horsepower calculator, and at 3600 lbs including driver weight, it should run around a 13.6-13.7 with 275-280 rwhp. But, that could be high or low, and we won't know... fo... sho... (couldn't resist)... until somebody actually takes it to a track and gets consistent times.
Old Sep 16, 2004 | 09:59 AM
jgsmuzzy's Avatar
QUOTE
He is talking about the car as if it is his. How did he get it before shipping date??
