I need 05 GT shifter bracket
Old Dec 15, 2013 | 12:05 PM
wrsexton's Avatar
Hi all, I'm converting an 05 GT from auto to T3650. I bought everything from the engine back to get all parts. Turns out I got everything except the U-bracket that holds the back of the shifter to the transmission tunnel. This part is only available new by buying the complete shifter! Anybody swapped shifters that happens to have one left over? I'm buying!
Old Dec 16, 2013 | 06:25 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
Sounds familiar ?
I was just describing how to make one yesterday?
Old Dec 17, 2013 | 02:12 AM
John Rambo's Avatar
I would like to thank you for the efforts you have made in writing this post. your provided information is easy to understand and implement.
Old Dec 17, 2013 | 06:23 PM
tbear853's Avatar
Oh, I get your drift .... I posted short because I did not then know if he had read my reply to him on another place (he has now) .... but in case someone else is looking still .... here's my idea.
It's a piece that is reused when changing shifters .... but it would be so very very easy to make one from a few simple measurements, a vice, a piece of steel about 13/16" wide and say .... 1/8" thick and less than 8" long, add 4 bends, two holes, done.
Maybe someone will make a few measurements for you .... or you could simply measure the block of rubber there, make the U with mounting ears.
On width of the U part, make inside same as width of factory rubber, about 1-7/16" inside the U should do nicely (don't worry if the bends are some rounded and not sharp bends, the rubber is rounded some too at corners) ....
.... and on depth make it just deep enough to snug the factory rubber against the floor, about 1-1/2" inside measure.
Add a "wing" on each side about 1-1/2" or so each ....
.... then simply drill two 1/4" holes same distance apart as your mustang's two studs.
Clean and add paint.
I didn't crawl under the car, I just measured the red poly rear bushing that Hurst sent that fit my '08's bracket so nicely .... but I reused the OEM rubbers as less noise transmission to floor.
Jul 8, 2016 08:53 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
