How to remove and install new wheel center caps?
Old Feb 26, 2013 | 10:24 PM
mrp5150's Avatar
So the center caps on my wheels have the Ford logo all worn off, so I just bought a set of new ones. Same thing that's already on there. How exactly do the center caps come off and go back in? I really hope I don't have to remove the entire wheel. Can you just pry the center caps with aflathead screwdriver? I don't care if I break them taking them off, as long as I can put the new ones on fine. And do the new ones snap right in? Sorry, seems like such a minor procedure, but I don't want to mess it up, haha.
Old Feb 26, 2013 | 10:51 PM
Getportfolio's Avatar
Drill a hole in the old caps and use a strong hook to pop them off. Flat head will ruin the wheel.
Old Feb 27, 2013 | 06:04 AM
05YellowGT's Avatar
The caps have a ring with a gap on the inside that holds them in place , the ring should close a little when you push the cap on and snap back when it's on. If you want to remove them in one piece , you'll need to take the wheel off to remove the ring first.
Old Feb 27, 2013 | 06:39 AM
boss hoss's Avatar
I replaced mine with black gt center caps. l took off the old ones with a small screwdriver a little patience and a gentle touch. all 4 stock ones came off without any damage(saved them for possible future use) and the new ones popped right in.. I was dreading having to take off the tires, so I gave it a go and it worked out.. use something soft between screwdriver and rim to prevent damage to rim. a cloth or something at the pivot point to pry them off without exerting the force on the rim itself.
Old Feb 27, 2013 | 09:26 AM
mrp5150's Avatar
Thanks for the responses. Since I don't care if I break the center caps that are currently on the car, so I think I'll try to get them off gently with a flathead screwdriver. The drill idea is good too, but I don't have one.
Old Feb 27, 2013 | 09:34 AM
boss hoss's Avatar
just work your way around the cap not over prying any one area and you should be fine.. might have to go around each one a few times to slowly get it off without damaging/scratching the rim
Old Feb 28, 2013 | 10:53 AM
zipperhead's Avatar
These pop right off from the inside once the wheel is removed from the car.
Old Feb 28, 2013 | 02:48 PM
This made me chuckle.^
Old Feb 28, 2013 | 03:01 PM
shurtual86's Avatar
agree
Diode Dynamics
Jun 12, 2018 03:26 PM
Jul 17, 2015 05:40 PM
