High Beam Issue
High Beam Issue
I have a 2009 Mustang GT with HID headlights.I have no high beams on either side.
The high beam indicator in the car works OK. I checked the high beam relay and high beam fuse. Al checked out OK.
I can hear clicking when I switch the lever in the car.
The car only has 20K mi, so I doubt bad bulbs or HID system.
Any ideas?
Any ideas?
Unless the car has very high mileage? I would agree with your statement. Being that the OP's car is a 10 year old 2009 model, I would say that it's more than likely due from the age of the car that's causing problems with the electrical system. Therefore, I would start there by having the electrical system/switches checked out. Anyhow, just saying.
Any ideas?
Any ideas?
usually the obvious answer is the high-beam bulbs have burned out . . . but I guess that does not apply to HID's . . . does anyone know how the HID high beams actually work; is there a shutter of some kind that covers the top when on low beam, or is the lens aimed up and down?
knowing how it works might help figure out what is going on, LOL
Tms Mustang Member ------ The Customizer!
....you can check if the two wires ( red/white -low beam and yellow white high beam ) are hot at the connector that sits at the head lamp assy. if yes - your problem might be the ballast assy or the HID bulb
. BUT BE CAREFUL. the ballast assy is a HIGH VOLTAGE PART . So the high tension can be very dangerous !!!
I changed my HID for the "normal" H13 System. Was a simple swap. and the light is still o.k for me
Greetings Juergen
Greetings Juergen
4stangs
2007-2009 Shelby GT500
14
Jul 21, 2010 01:05 AM
