Help! DSS driveshaft is too short.
Old Jan 20, 2013 | 08:58 PM
2007CalSpec's Avatar
Exclamation Help! DSS driveshaft is too short.
I started my DSS driveshaft install around 1pm today. I bolted up the front of the driveshaft but I can't bolt up the rear because the driveshaft seems to be too short. I've installed the black adapter plate to the pinion but there's a big gap between the pinion and driveshaft as you can see in this picture...
No instructions were included. Is there a particular order that the driveshaft needs to be installed like rear first and then front or vice versa?
Anyone here have a DSS driveshaft that can shed some light on this issue?
Thanks!
Old Jul 8, 2013 | 03:57 PM
kona stang10's Avatar
try bolting the rear up 1st!
Old Jul 8, 2013 | 04:43 PM
bob's Avatar
bob
Did the rear end shift any when you disconnected the factory shaft?
Old Jul 8, 2013 | 04:48 PM
Isn't there a yoke that slides?
EDIT: Didn't realize this was a resurrection thread.
1/20/13, 7:58 PM
Old Jul 8, 2013 | 11:08 PM
Yeah this is old. I solved the issue awhile ago.
Old Jul 9, 2013 | 11:24 AM
KdF's Avatar
KdF
AND???????
Kmon, spill it.
Old Jul 9, 2013 | 08:49 PM
Originally Posted by KdF
AND???????
Kmon, spill it.
I solved the problem and posted the solution on another forum. Rather than write a page on what I did, here's a link.
http://mustangforums.com/forum/2005-...too-short.html
iceD
Apr 10, 2016 12:59 PM
PonyMuscletang13
Sep 24, 2015 01:40 PM
houtex
Aug 13, 2015 05:04 PM
John H
Aug 8, 2015 04:58 PM
