Help! Auto Trans Kickdown Lag
Old May 23, 2005 | 03:32 PM
Original Sin's Avatar
What a great transmission these auto's are - in straight line WOT mode. But kickdown when you need it during a normal drive is 1 to 1.5 seconds away from when your foot tells you you need it. This drive by wire stuff if crap.
Anyone out there come up with any solutions or fixes???? There's got to be something!!
Thanks - any suggestions are appreciated.
Mark.
Old May 23, 2005 | 03:44 PM
MustangDan's Avatar
Unhook the battery and retrain it to you liking.
Old May 23, 2005 | 05:22 PM
dave_bought_another_black_stang's Avatar
search for a thread on the diablosport tuner. I had a local get together here in jax, one guy had an auto with this tune and even on the mildest tune, the lag was gone. Mine is an auto and i am getting one as soon as i get back from my surf trip to el salvador!!
Dave
Old May 23, 2005 | 05:55 PM
Badandy's Avatar
hmmmm. interesting.
I just push my clutch down and shift into appropriate gear and no lag :scratch:
Old May 23, 2005 | 09:28 PM
StangFreak's Avatar
Mark.
See this thread I posted earlier this week. Alternative Auto has the solution to your problems.
http://forums.bradbarnett.net/index.php?showtopic=24830
Old May 24, 2005 | 12:08 AM
Thanks Jim, I'll check them out. But that Lentech thing looks pretty interesting.....and pretty pricey too.
Old May 24, 2005 | 01:20 PM
ChrisM's Avatar
Mark.
Check out this thread, particularly post #11. I tried it and it helped mine - see my response at post #41.
http://forums.bradbarnett.net/index....opic=10690&hl=
It's quick, free and painless - whether it works for you or not!
Old May 24, 2005 | 02:36 PM
sranger's Avatar
Call Alternative Auto, give them $425 on the credit car, and problem solved....
It is a lag in the computer system that the FORD engineers put in to reduce the shock on the trans during a down shift....
A tune is the only way to completely remove it at this time....
Old May 24, 2005 | 03:51 PM
Alternative auto USES the Excalibrator for the tune.
Old May 24, 2005 | 04:26 PM
StangFreak's Avatar
One important factor to keep in mind with the auto trans in these cars is it's only good for about 400 - 450hp as confirmed by Lentech. (see other thread listed above). Any more than that and your pushing your luck.
Gigantor
May 11, 2023 07:31 PM
GTPETE
Oct 12, 2015 02:20 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
