Help???2005 totally dead
Old May 27, 2019 | 11:03 AM
Tommy123's Avatar
Security lite wont go off and have no power to anything except lightes door lochs and horn. I tried factory reset and still nothing
Old May 28, 2019 | 07:00 AM
check the charging system. Does your battery show at least 12 volts?
Old May 28, 2019 | 01:34 PM
m05fastbackGT's Avatar
When you mentioned trying factory reset and still nothing, are you referring to disconnecting the battery and then reconnecting it? Or are you referring to returning your car's ECM back to factory stock with a handheld programmer, as in SCT?
If you suspect that it's the battery, how old is it? if your battery is "OEM" Motorcraft and is over 3 years old and notice your radio is turning itself on and off, along with your lights flashing and active security system sounding the horn on and off? this usually means your battery is nearly completely discharged and requires replacement!
azoufan
Dec 14, 2013 07:00 PM
The Deviant One
05-09 Exterior Modifications
35
Nov 14, 2005 06:46 PM
Torch_Vert
Sep 24, 2005 07:54 PM
vito57
Sep 13, 2005 10:12 AM
SixtySix
Dec 9, 2004 02:51 PM
