Heater/Defrost airflow balance
They can all they have to do is plug in the computer and tell it enable, but when this feature first started some owners walked out to thier cars and found the windows down , when they had in fact left them up, I in that case would rather do it my self then its human error not mechanical interferance. I do like the bounce back safty in the windows if someting blocks window from closing it snaps down or open .
To try and get heat out the floor only I have put it in floor/dash mode and closed all the dash outlets. This doesn't do too bad a job but the dash outlets can get pretty hot. At least in this mode I can get it to the floor without fogging up the windows.
Guys there is another post on this a few down from this one or the previous page. It is a new post. I just went through this and took my car in and the dealer ordered a new heater control....apparently the entire unti you see in the dash. Anyway they swapped it out and it works fine. Mine started out as a flow control issue but over time when you would put the selection in the off position it wouldnt shut off and I actually had to put it one to thr right of off to work. It was as if everythign was off by one. Tell your dealer not to be a dipsh*t and fix the issue.
Supposedly the problem was if the door was opened in the rain and the controls got wet, the windows could open by them selves.
Evil_Capri
9/11/15 08:39 AM
9/8/15 10:45 AM
9/1/15 01:19 PM
Ecoboost
7/25/15 06:32 PM
