headlight switch illumination bulb
Old Dec 14, 2011 | 02:30 PM
rds1952's Avatar
s197 - 2005-09 Mustangs
I expect a lot of you have had a burned out bulb inside the headlight switch.
Your loving dealer will be happy to tell you there is no part number and can only offer to sell you the whole switch. Who wouldnt want to spend $60-80 bucks for a $2 bulb.
Wondering if any of you have found a suitable replacement. I heard of a few, but not as much light as original. I might try one of my left over clear bulbs from when I did my own interior lighting on my 07. Of course, I'll have to do a little soldering and handle very carefully reusing the old lamp holder.
bigrich
Old Dec 15, 2011 | 02:46 AM
HizliBullet's Avatar
I found one for $25 used on eBay, seller charging $20 to ship to west Canada from Michigan
http://bit.ly/sFT2mN
Old Dec 17, 2011 | 06:43 AM
MTAS's Avatar
Mine burnt out 2 years ago. No biggie and not worth the hassle/money to replace it.
Old Dec 20, 2011 | 03:07 PM
Stormbringer's Avatar
I don't think my headlight switch has ever lit up, from the day I bought it. I just assumed that it didn't...
Old Dec 20, 2011 | 03:18 PM
I'll be d*mn... There's a burnt out bulb in my headlight switch...
Old Dec 20, 2011 | 05:36 PM
Well I changed my bulb.
I can only make the following recommendation...
Purchase a small 12v incandecent lamp from radio shack. I used Part number 272-1154
http://www.radioshack.com/product/in...ductId=2104023
Unwind the leads off your existing bulb from the socket and remove.
Cut these leads off your old bulb and solder them to the shorter leads on the new bulb.
Install the new bulb to your old socket and install back into the headlight switch.
You should end up with something that looks like this.
EDIT: Or you could probably just order one of these...
http://www.bulbtown.com/7219_MINIATU...ASE_p/7219.htm
Old Jan 14, 2016 | 01:32 PM
randyre's Avatar
Old post, but feel that an more modern updated fix the problem was warranted.
Found a LED based bulb and as of Jan 2016 its only $2.40shipped for two of them, this includes the LED and Neowedge base.
http://www.wardenjp.com/stores/neowedge.html
The other option is a pre-wired SMD LED.
http://www.ebay.com/itm/0603-SMD-LED-10pcs-Pre-soldered-Micro-Litz-Wire-BLUE-RESISTORS-3V-12V-small/231726815468?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35006%26meid%3D3844354e244d4a25a97929a7f075e176%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D231743402902
Old Jan 29, 2016 | 02:25 PM
OneCoolGT's Avatar
I knew that used to light up... I looked one night and only the little fog light thingie lights up but nothing else.! Guess I'll be inquiring about that the next trip to the dealer and see what they say....knew I wasn't going crazy...at least not yet!!
Old Feb 6, 2016 | 04:13 PM
mrkabc's Avatar
DON'T have the dealer sell you some stupidly priced light bulb. Get the T4 LED Neo Wedge bulbs.
http://www.ebay.com/itm/2pcs-T3-T4-T5-Neo-Wedge-Dash-LED-Bulbs-Blue-White-/381536039164?hash=item58d551f0fc
$2.99 from this seller, get the white color since the light switch is filtered internally with green. (the blue won't light up that well and it will still be green.)
I bought these March of last year after discovering my light bulb had long since burned out - it wasn't pretty.
Fixing it is easy - the entire headlight switch assembly just snaps out. Use a plastic interior trim puller (essentially a flat plastic screw driver) to pry out the headlight switch, disconnect, and then remove and replace the bulb using a large flat screwdriver. It's a simple half twist to remove/replace.
Now plug in the headlight switch and turn on your headlights. If the LED doesn't light up, you have the polarity backwards. (it's directional). Pull the T4, turn it 180 degrees and reinstall. Turn on headlights again to test. If it lights up, then snap the assembly back into the dash - you're done!
It's EASY and for around three bucks a no-brainer repair.
Old Feb 7, 2016 | 11:03 PM
randyre's Avatar
Just got the ones I ordered in the mail. Came from Japan, worked flawlessly. And yes use the white. I also ordered them in green and was a little dull. so went with the white.
2pcs T3 T4 T5 Neo Wedge Dash LED Bulbs Blue White | eBay
Old Jun 17, 2017 | 08:32 PM
autopro5's Avatar
I found this replacement and it works great. http://audioxpress.org/listing/05-06...ch-light-bulb/
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
