GT yellow driving lights
Many have said they don't like the driving lights up front. Is there a yelloe bulb that would fit instead and would that change the look to make it more agreeable to those that want change.
upstate
I think I understand what you mean. You want a yellow BULB not LENS. This way the lens still looks clear during the day, but at night will be yellow.
I'm sure you will be able to find something in yellow, There are some SCCA Rally specialist that have all kinds of lights & bulbs.
I'm going to replace the fogs with very clear high powered driving lights & update the stock headlight bulbs to a higher output. Then I will put rectangular clear fogs in the blanks on the lower grill.
The best part will be my "move over signal." I will wire the headlights & driving lights into a relay that pulsates them back & forth. I will have a switch mounted on the center console for this purpose.
already have a 90 watt strobe kit ready to be installed in the pony when I get it, the two front light strobes will be in the fog lights and the other two in the tailights, but i'm also hooking up 2 separate mini blue strobes in the grill, I've got a hike to get to my firestation but it'll be much more easier now with this kit........
MaverickMLFFD371 in New york that's illegal. NJ must be more lieniant. In NY any flashing white light, front or rear is illegal. Yellow flashing or revolving is OK, plows on pick ups, etc.
Originally posted by V10@October 22, 2004, 7:44 PM
Wait until state troopers start getting 2005 Mustangs and you see one running up behind you with flashing red and blue lights in the grille.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
