GT/CS bolt on side scoops question
Old Apr 24, 2010 | 03:18 AM
HizliBullet's Avatar
general question about side scoops: are they strong enough to withstand a flying rock on the highway? anybody here have the bolt on ones? could i get your stories what i should be careful about once its on there, and since its bolted, what would happen if one did crack and needed replaced etc
Old Apr 24, 2010 | 05:47 AM
WaltM's Avatar
If your worried about durability, get the ones made by 3dcarbon. They're urethane and just stick on.
Old Apr 25, 2010 | 12:54 AM
i want the exact same ones on the gt/cs, those arent bolt on as far im concerned they're bond on
Old Apr 25, 2010 | 08:53 AM
Tispco's Avatar
I have the GT/CS scoops. They are bolted on as well as taped. I have removed one for a quarter panel repair and there was no issue taking it off and reinstalling it. No issues with rocks either in 12,000 miles.
Old Apr 25, 2010 | 09:05 AM
WaltM's Avatar
The ony reason I recommended those is because there's no drilling involved. Once you drill, you'll have potential rust points and the possibility of misdrilling during the installation.
Do what makes you happy!
Old Apr 25, 2010 | 09:40 AM
05stangkc's Avatar
Anything Used by the Factory has to pass National Highway Safety Standards. So they should be good to go! These scoops use Double stick and pins. {Some} Choose not to use the pin and have had fine results. If I put some on my car I would likely not want to drill. But that's me.
https://themustangsource.com/showpos...17&postcount=2
Check Pdf for Supersnake on how they install.
KC
Old Apr 27, 2010 | 02:16 PM
Rays197's Avatar
They will withstand that if you snap them in and use the tape. easy install comes with a pattern to tape for drilling. After I drilled the holes I used a small brush and painted inside and out of the drilled holes.
Old Apr 27, 2010 | 05:22 PM
nite's Avatar
42K mi, 160+ mph, and no issues to date.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
defiance772
Oct 21, 2015 09:37 AM
Last1
'10-14 Exterior Modifications
Aug 13, 2015 01:16 PM
glo106
Aug 11, 2015 08:29 AM
Kgilly
Jul 9, 2015 01:47 PM
