Got A Problem, Steering Wheel Shimmy!
Old May 12, 2008 | 01:22 PM
FRONCZ's Avatar
REMOVE THE RETAINING CLIP AND REMOUNT THE TIRE SHOULD TAKE CARE OF THE SHIMMY. IF NOT THE BALANCE IS MOST LIKELY OFF (OR WORSE CASE SCENARIO TIRE COULD HAVE A BAD BELT) EX-GOODYEAR SALES MGR.
Old May 12, 2008 | 03:51 PM
Treadhead's Avatar
Mine did the same when I put my wheels on. I had to get a hub spacer thing(Can't remember the real name for the life of me) to get rid of it.
If I remember correctly I was told something about the rims being either hub centric or lug centric and the spacer fixed it. Anyway, my wheel shemmy was gone afterwards. So if none above the above works you check that out.
Old May 12, 2008 | 05:08 PM
highvolts's Avatar
Originally Posted by Dan
Anyone have the clip problem with the fanblades??
Not me. Factory fan blades have the recesses for the clips.
Old May 12, 2008 | 06:36 PM
Dineau's Avatar
1. Yes for Razors you will need a centering ring, this will ensure that the wheel is perfectly center when you tight it down.
2. With OEM wheels you don't nee to remove the clip has they have the recess around the stud to make sure the wheel sits flat on the disk, but with after market you need to take it off otherwise the wheel will be balanced but not sitting flat on the disk.
Old May 13, 2008 | 09:58 PM
Dan's Avatar
Dan
Do You Remember Me?
Well, that eliminates the clips as the cause of my problem since I have fanblades.
Can worn tires cause this?
Old May 14, 2008 | 05:14 AM
boss429man's Avatar
Since it,s above 50 I say tire balance but while the tires are off take the clip off and remove any build up of rust at the base of the lug?
Old May 14, 2008 | 01:12 PM
Robbieg's Avatar
Originally Posted by Got Oatz
Did you just change from stock wheels to the Shelby's? Did you remove this piece before replacing the rims???
Mike
Originally Posted by highvolts
Check this first!
Originally Posted by adrenalin
+2
+3...I had the same problem when I put the my Razors on, so I ordered a set of hubcentric rings and when they came in I put them on and took the clips off and now it's as smooth as butter going down the road.
Old May 16, 2008 | 08:15 AM
mot250's Avatar
yes or it could mean you lost a press-on wheel weight.
If you have the time, try swapping tires around the car to see if the shimmy goes away. If it does, then it is a tire balance issue. If it doesn't, it does not rule out a tire balance issue, it could just mean all of your tires are out of balance.
Old May 16, 2008 | 01:10 PM
MaverickMLFD371's Avatar
thanks for the input fella's.
i took the wheels off and the clips weren't there, so we can rule out the clips being the problem. I'll see if I can rotate the tires and see if that gets rid of the shimmy.
took me half a day to find out what places have a roadforce balance machine and there was only 4 shops within a 15 mile radius. I will end up taking it for a balance test Tuesday.
mkj5013
'10-14 Interior and Audio
Dec 13, 2015 11:04 AM
Lake_Vert
Aug 11, 2015 06:40 AM
tdf017
Aug 5, 2015 10:13 AM
Vader99
Jul 19, 2015 08:19 PM
