Got A Problem, Steering Wheel Shimmy!
Old May 11, 2008 | 02:22 PM
MaverickMLFD371's Avatar
I recently had everything installed on my car, new shelby razor wheels, suspension components etc. got the car back and I noticed a shimmy in the steering wheel. I called a few guys and they said since you lowered your car, your car is out of alignment, thats why you have the shimmy. i felt confident with that since I knew I had to get a new alignment anyways. took it for the alignment 2 days ago, everything was good. drove it home, and above 50MPH I feel the shimmy again!! what gives??
what else can be causing the steering wheel shimmy?
Old May 11, 2008 | 02:34 PM
302svt's Avatar
Usually a shimmy is caused by the wheels not being balanced right.
Old May 11, 2008 | 02:41 PM
Treadhead's Avatar
Mine did the same when I put my wheels on. I had to get a hub spacer thing(Can't remember the real name for the life of me) to get rid of it.
Old May 11, 2008 | 06:31 PM
Got Oatz's Avatar
Did you just change from stock wheels to the Shelby's? Did you remove this piece before replacing the rims???
Mike
Attached Thumbnails Got A Problem, Steering Wheel Shimmy!-19933beaf6d948aebb2a44de16d1eb67-1-.jpg
Old May 11, 2008 | 06:39 PM
antdog's Avatar
+1 on the wheel balance
Old May 11, 2008 | 08:18 PM
300GT's Avatar
Mike
what is that part and what is it's function?
Old May 11, 2008 | 08:21 PM
Got Oatz's Avatar
It's a keeper clip used to hold the rotor in place on the production line. The problem is, with many after market rims, they do not have the tolerance to accept these clips, and making it impossible for the after market rim to sit flush against the rotor.....
It can cause shimmy......
Old May 11, 2008 | 08:29 PM
Torrence's Avatar
The wheels need to be balanced correctly.
Old May 12, 2008 | 06:26 AM
highvolts's Avatar
Mike
Check this first!
Old May 12, 2008 | 06:37 AM
adrenalin's Avatar
Mike
+2
Old May 12, 2008 | 08:48 AM
GPStang06's Avatar
More then likely a balance issue if you did indeed remove the little spacers posted about. I removed mine when I did the rotors a while back and I as well have a slight "shimmy" after installing my Razors at and about 50 mph. I just haven't gotten around to having them rebalanced yet.
Old May 12, 2008 | 08:54 AM
Dan's Avatar
Dan
Do You Remember Me?
Anyone have the clip problem with the fanblades??
Old May 12, 2008 | 08:55 AM
adrenalin's Avatar
How is that possible? When you have a tire balanced, it is performed when the tire is NOT on the car. Removing the retaining clip would not have any impact on balance. These clips need to be removed for several aftermarket rims and any spacers that are installed. If the clip is not removed the rim is not mounted flat to the rotor at that one lug.
Old May 12, 2008 | 08:56 AM
holeshot's Avatar
I have the same shimmy. 20" razors and its lowered with sportline springs. Had it aligned too.
I will have to check if i have that clip on mine.
Old May 12, 2008 | 08:58 AM
bpmurr's Avatar
Making sure the clip is removed and a road force balance should take care of the Shimmy. That's what happened when I first got my rims. Of course back then few knew about the clip on the rotor.
adrenalin's Avatar
I should point out that I had this problem on a Jeep liberty and my 97 mustang when I had changed rims and forgot to remove the retaining clips.
Old May 12, 2008 | 09:04 AM
300GT's Avatar
so once the car comes off the assembly line, is there any reason to keep the "keeper clip" on, even if you are running factory rims?
Old May 12, 2008 | 10:11 AM
bpmurr's Avatar
No, you can chuck them.
Old May 12, 2008 | 10:37 AM
GPStang06's Avatar
Actually I was implying that if those retainer clips actually did cause a vibration, that it wasn't the cause of mine since I took them off when I changed the rotors a while back. I have no idea if they could cause a vibration. I was simply stating that I don't have the retainers and do have 20" razors and have the same shimmy.
Old May 12, 2008 | 12:37 PM
adrenalin's Avatar
Ah, I read your comment wrong. Sorry about that.
Another thought could be if they used the stick on wheel weights on the inside section of the rim, one may have fallen off and put it out of alignment. A co-worker just received a set of rims from 1010tire, and as he took the first one out of the box, one of the weights fell off.
