fuel enhancer
Old May 25, 2007 | 07:09 AM
Clark Kent's Avatar
fuel enhancer
what type of fuel enhancer and/or cleaner do you guys use and how often
Old May 25, 2007 | 07:21 AM
Dougxox's Avatar
drive fast don't let anything collect.
Old May 25, 2007 | 07:29 AM
kevinb120's Avatar
BG44k is the best by far.
Old May 25, 2007 | 07:57 AM
HOSS429's Avatar
legacy Tms Member
same here " foot lead " ;;; i mean " lead foot "
Old May 25, 2007 | 09:28 AM
zaghloul's Avatar
I've got a lead foot too. Does that really help? I've read a post about Forte Gas Treament before http://www.forteuk.co.uk/Gas_treatment.htm . Thinking of trying it out myself.
Old May 25, 2007 | 12:39 PM
theedge67's Avatar
None, just run a good quality fuel...anything top tier rated. No fuel system treatment necessary. Some can even foul plugs and screw with injectors.
Old May 25, 2007 | 01:11 PM
Donna's Avatar
Queen Of Nascar
+1 I have read that too many times before.
Old May 25, 2007 | 01:26 PM
kevinb120's Avatar
For a real system cleaner the only one that truly works is BG44K. You should see what it does for quad carb motorcycles
I see newer car engines taken apart all the time, they definitely get dirty, and the fuel injectors should be cleaned periodically. You should only do it at recommended intervals though, no need to use it all the time.
Old May 25, 2007 | 03:54 PM
Agleon's Avatar
What gas stations do you guys go to? Which stations do you consider to have good quality fuel?
Old May 26, 2007 | 03:38 AM
Indystang's Avatar
I use Shell gasoline and Redline Fuel System cleaner every 3-4K miles. Any Brand name Gasoline should help prevent excess build up but you still need to keep the Injectors clean.
Old May 26, 2007 | 02:59 PM
theedge67's Avatar
Go to www.toptiergas.com there is a listing of all grades that meet the top tier rating. Best gas you can get.
Old May 26, 2007 | 03:58 PM
Agleon's Avatar
Looks like BP or Citgo aint there.
Old May 26, 2007 | 07:21 PM
bob's Avatar
bob
I do that every 3 oil changes, in the mean time I use Lucas Upper Cylinder Lubricant between BG44k applications.
NC14GT
Feb 20, 2023 09:42 AM
Sep 23, 2015 03:21 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
earl610
Sep 6, 2015 05:48 PM
