fogs not working.. hmmm
weird. The foglights don't work on my new GT. Before I take to the dealer to have em fix it, is there anything I can look at to figure out why? My high beams are not on.. Where is the fuse for it??
Thanks!
Thanks!
They cover this in the owners manual if you dare read it from cover to cover like when I first got my car...
If the switch doesn't work, this is the sort of stuff they do.
Fog_Lamps[1].pdf
Fog_Lamps[1].pdf
Make sure your brights aren't on.
While ago I turned on my parking lights and fogs for my 8 block drive home and the fogs wouldn't come on. I was like wtf! Well my brights were flipped on the last time I shut them off. Flip the stalk and the fogs came on.
like I said in my first post, the brights are NOT on
thanks..
thanks..
Personally, I would just take it to the dealer and let them deal with it. No point in messing around with it if it is covered. If you did find something such as a bad fuse, would that mean you would also find the root cause of the fuse blowing in the first place?
good question. I did not check that. I will and get back...
Im assumming the bulbs are good.. The car is a year old. whats the chance BOTH bulbs blow after one year??
Actually, if the bulbs don't light, the indicator light won't come on. Its powered through the bulb filament. I found this out when I upgraded my fogs to driving lights. Even though the fog light relay was on, the indicator would only come on if I had at least one bulb in the factory harness.
