Fog lights are out....
Old Mar 15, 2011 | 10:03 PM
cmplxlgc's Avatar
Arrow Fog lights are out....
I was leaving work tonight and noticed in the reflection in the car in front of me that my fog lights weren't on. I flipped the dial back and forth again, the fog light indicator on the switch is on, but they're not. I thought maybe it was a fuse, so I swapped as a 15A in - no dice...
Any thoughts? I dont think it could be the bulbs (both at once?) since they're relatively new.
Old Mar 16, 2011 | 08:17 AM
antdog's Avatar
Were your brights turned on?
Old Mar 16, 2011 | 10:22 AM
jayguy's Avatar
What he said. Fogs turn off when brights are turned on.
Although it is also possible that they are both burned out. I would find that odd though. I just replaced one of mine after 4.5 years and 48,000 miles, and mine are always on.
Watch out when you replace the bulbs, I had the metal shield thing inside the housing fall off, and there's no way to get it out or back in right. I'm going to have to buy a whole new fog lamp for the passenger side.
https://themustangsource.com/f739/fo...inside-492498/
Old Mar 16, 2011 | 02:01 PM
cmplxlgc's Avatar
Im well aware of the fog/high beam thing. I'm just trying to eliminate the most obvious. Not fuses, bulbs, switch...
What could leave the dash indicator on, but the lights remain off?
Old Mar 16, 2011 | 07:13 PM
cmplxlgc's Avatar
If nothing else, where could I get a wiring diagram of the fog lights? From a installation guide for example.
Old Mar 16, 2011 | 08:24 PM
ford4v429's Avatar
legacy Tms Member
hate to ask a dumb question, but if theyre both relatively new, were they relatively plugged back in?
seriously, there should be a relay under the hood, I have diagrams here somewhere, will put one up if I can find it.
Tim
Old Mar 16, 2011 | 08:32 PM
Shotokan1509's Avatar
It is more common that you'd think for 2 bulbs to go out in short succession. I had the headlights on my dd go out within a 24 hour period.. not fun driving home in the dark alternating between highs & fogs only depending on traffic.
Old Mar 16, 2011 | 08:41 PM
cmplxlgc's Avatar
They're new in the sense that they're only 2 years old. I mean I should get more than 2 years outta a pair of bulbs and they've been working fine. I've had my car for 4 years, so I'm familiar with the typical issues. It's just this has me stumped.
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
