Fog light lens haze
The H3 bulb (used in the PIAA driving lamps) has a rated lifespan of 35-550 hours (130W / 55W respectively) while the H10 bulb has a rated lifespan of 1000 hours. Keep in mind these are lab lifespans (no vibration, etc...) The H3 has 103-250 candle power (again, 55W / 130W respectively) while the H10 is only rated at 65 candlepower.
The H1 has an even shorter lifespan at 300 hours.
I too often get flashed when using the fogs......especially by Porsches! Maybe because they sit lower the light seems brighter...I am running Silver Stars. Any idea how the PIAA's compare??
If you look at the beam pattern for the fog lamps, you will see that quite a bit of light encircles the lamps about 4 feet above the hood at close range. So at 60 feet, there's a LOT of light being thrown upwards towards pickup truck drivers
Well, if you use your fog lamps all the time...I would think that the overheating is causing them to haze...the fog lamps were not designed to be on all the time...only when you need them...hence the term "fog" and not "driving lamps"...besides it's probably a PITA to change them...so use them sparingly....
Exactly! I see guys using them all the time just because I guess they think it looks cool. The fogs on my '05 still look good because I use them only when they will make a difference, not how it looks to others who see me coming.
I think it is the reflector material or the plastic lens material gassing off due to the heat generated from using the lamps. However, people have noted that the foglamps are hazy right from the get-go. I bought a 40mil protective film for the lamps and I can tell the foglamps get significantly hotter than the headlamps.
Well my Foglamps have only been used once and they are hazed so use has nothing to do with it.
I am however very interested in the PIAA setup. Be nice to have some more info on them and how they install. They market them as a replacement but then say they include a mounting bracket and relay. So i am curious to know how they mount and hookup. Obviously you will have to run a power supply wire to the battery but i would guess you could use the stock wire as the trigger signal for the relay.
Richard
Richard
Please notice that the PIAA 4064 light that was listed is a driving lamp and not a fog lamp. It only has a 30 degree beam spread whereas fog lamps have a beam spread of greater than 90 degrees. Replacing a fog lamp with a driving lamp will be useless in foggy conditions. The fog lamp has a lens that cuts off the beam at a certain height just like your low beams, this reduces reflected glare back towards you. A driving lamp with a 30 degree cone is just that, a complete cone with no vertical cutoff, and since they are rated at a higher wattage they will reflect a lot of light back at you. If you use it to replace your fog lamp and then hook it up to existing wiring then it will only work with your low beams as that is how the fog lamps are wired. Unfortunately driving lamps are designed to compliment high beams and not low beams.
From the rocket ranch
BB
Semper Fi
BB
Semper Fi
#40
Richard
Richard
Okay,Lets say I never need foglights (I don't) or I can install additional ones.
If I use the PIAA set-up and original wire signals to their relay, can I just switch the headlamp wires so the high beams come on with the dash switch?
Wouldn't the low beams come on with the stalk switch?
Wouldn't the fogs (driving lights) come on with highs only?
Would the smart junction box still be happy?
