Flash2Pass garage opener
Old Apr 8, 2005 | 12:32 PM
farmerjohn's Avatar
Several weeks ago someone posted info on the Flash2Pass garage door opener.
I checked out the website and ordered one. I installed it in the Mustang a few minutes ago and it is really neat. When you double-click the high beams the garage door opens/closes.
A special receiver replaces the wall mounted door opener and a transmitter mounts under the hood of your car. Two wires from the transmitter attach to the high beam side of the headlight harness. The first time you click the flash to pass feature the transmitter powers up, the second click of the flash to pass triggers the door to open/close.
Very handy and only $100.00.
John
Old Apr 8, 2005 | 12:37 PM
Altoid's Avatar
Jackass
Works so good it had to be posted twice!*
*May not actually work.
Old Apr 8, 2005 | 05:02 PM
groupset's Avatar
Could you tell us which wires in the Mustang you spliced into to install this? Thanks!
Old Apr 8, 2005 | 08:05 PM
blast461's Avatar
John, this does not sound very secure. How does it prevent un authorized access to the garage?
Old Apr 8, 2005 | 08:41 PM
emperorjordan's Avatar
no no no, it wont open when anybody flashes their lights..... when you flash your lights, it triggers the transmitter that is hooked up to your headlights which sends the signal to open the door.
Old Apr 8, 2005 | 08:56 PM
DADS05's Avatar
Originally posted by blast461+April 8, 2005, 7:08 PM--><div class='quotetop'>QUOTE(blast461 @ April 8, 2005, 7:08 PM)</div><div class='quotemain'><!--QuoteBegin-farmerjohn@April 8, 2005, 2:35 PM
[/b][/quote]
Here we go again, It works on radio frequency just like a regular garage remote, not on light waves. read the link posted above. It is a very secure system.
Old Apr 8, 2005 | 09:03 PM
Badsnke98's Avatar
Cheaper and easlier to use the remote that came with the door opener. Even buy a third or four one for $39. (mine) or less.
Old Apr 11, 2005 | 04:38 PM
farmerjohn's Avatar
Altoid - no problems so far. Have one on an 05 Mustang GT and one on an 05 Escape.
Groupset - I installed mine on the passenger side light harness. There are three wires leading to the female connector that plugs into the light bulb holder. Green, Black, and White. I used the black and the white wires to wire in the transmitter.
Badsnke98 - Yep, I coulda done that, but I don't like having a remote clipped to my visor, or searching for the remote after it falls off the visor. Now my opener is always at my fingertips.
One word of warning for any others who may go with a flash2pass. As you already know, the turn signal lever is also used to flash brights, and to turn on/off brights. When you pull the lever toward the steering wheel, the first detent is flash brights and the second detent is turn on/off brights. If you install a flash2pass opener, make sure you only pull the lever to the flash bright detent. If you pull al the way to the turn on/off brights detent, it will not work.
John
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
