First start of day is slugish
Old Jul 9, 2012 | 08:53 PM
ajrami33's Avatar
Ok I can't figure what it can be I start my stang in the morning and it's slow to start. The rest of the day it starts up like a champ. It's always in the morning or when I wait for 12 hours or more. Can some one shoot me in the right direction or help me to solve what it is? Thanks
Old Jul 9, 2012 | 10:39 PM
antdog's Avatar
The first thing that popped in my mind is the fuel filter.
Old Jul 9, 2012 | 11:30 PM
ajrami33's Avatar
Changed it. Along with spark plugs and wires oil and filter.
Old Jul 10, 2012 | 08:22 AM
05YellowGT's Avatar
Battery going bad ?
Old Jul 10, 2012 | 08:42 AM
Gster's Avatar
Engine temperature sensor or coolant temperature sensor? Have u hooked it up to a diagnostic computer?
Old Jul 10, 2012 | 01:32 PM
ajrami33's Avatar
ive used a tunner diagnostic and nothing shows. the battery and altenator where changed 1 month ago.
Old Jul 10, 2012 | 02:55 PM
Did it start having problems after that? Have you tried disconnecting the battery again to reset the ECU?
Old Jul 10, 2012 | 03:47 PM
ajrami33's Avatar
Yes I've disconnected the battery and it didn't start right after I changed the alternator so I don't think that has anything to do with it. It makes me believe it something with the fuel. Cause it only dies it at the beginning of the day.
Old Jul 10, 2012 | 03:55 PM
Gster's Avatar
If one of those temp sensors are bad it tells the computer the car is warm when it's actually cold so it runs rough. Because its summertime the engine isn't really cooling off. That's my best guess. You can wait till winter and if one is bad it will run rough with every start.
Old Jul 10, 2012 | 07:41 PM
ajrami33's Avatar
How do you know if it's bad
Old Jul 10, 2012 | 08:03 PM
Gster's Avatar
Unless its coming up on the computer you won't know. Did you hook the diagnostic up in the morning when it was cold? If its not to annoying wait til the weather cools off. If it runs rough until it warms up every time you start it that narrows it down. You've already done everything I would have started with.
Old Jul 10, 2012 | 08:09 PM
Gster's Avatar
It could be your O2 sensors also. Try to get a computer to tell you what it is.
Old Jul 10, 2012 | 10:43 PM
ajrami33's Avatar
Ok I'm going to try the morning with the diagnostic
Old Aug 7, 2012 | 03:12 PM
ajrami33's Avatar
Here is my update of what fixed it.... Sorry I'm late on it. For 3 days I would turn the ignition on 10 times ( not crank to start but just where you here the dings to buckle up and the lights and gauges turn on) only at the first start of the day. The 4th day came around and it started right up and ever since. I don't know why this worked, but maybe one of you guys can explain the WHY.
Old Aug 11, 2012 | 05:24 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
I noticed my first start up was very sluggish several days in a row where at the point of start up low RPM and a sputtering was the norm. The cure I seem to have found was letting the car "prime" a little longer. Just turn the key to the On position, let the dings expire, give it another second then crank. Haven't had a slow start up since.
DarrenGT
Aug 19, 2015 08:22 AM
Beavis9000
Aug 10, 2015 12:16 PM
07 Boss
Aug 8, 2015 11:04 AM
ClayP
Aug 3, 2015 09:00 PM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
