Finally...Fuel Tank TSB
![Thumbs down](https://themustangsource.com/forums/images/icons/icon13.gif)
Mine's on order...
Enjoy
FORD: 2005 Mustang
ISSUE:
Some 2005 Mustang vehicles may exhibit the fuel tank being slow or difficult to fill. The condition may be described as, repeated rapid shutoffs of the filling station pump nozzle, or multiple nozzle shutoffs when attempting to fill the fuel tank. The condition may be due to the fuel tank vapor venting system inside the fuel tank.
ACTION:
Install a new fuel tank. The new fuel tank has a revised internal venting system to improve fuel filling. Remove the fuel tank assembly per Section 310-01 of the Workshop Manual.
PART NUMBER PART NAME
5R3Z-9002-AA Fuel Tank
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
EDIT...TSB
FORD: 2005 Mustang
ISSUE:
ACTION:
WARRANTY STATUS:
EDIT...TSB
I lust for a M24
Mine is scheduled to be built week of Feb 28. Does anyone know if Ford will put the new style tank on or will they make me take a trip to the service dept later? Git-r-done right the first time, I hope.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
The new tank is scheduled to be installed in production as of 2/16/05 the service part is currently backordered with 400 intransit. The old part # is still available please remind your dealer the TSB calls for the Late production part#
Hows that!
kc
Hows that!
kc
Originally posted by ManEHawke@February 18, 2005, 4:52 PM
Every car that is being built currently is built using revised parts in areas that have been faulty right?
Doesn't sound like it
![Nonono](https://themustangsource.com/forums/images/smilies/nonono.gif)
Wow, first I get the Shaker Series B to fix the problems with the audio system, now I'm going to get the new fuel tank to fix the problems with the pump shutoff! I am beginning to think that waiting to place my order is working out to my advantage!
Sean
Sean
Originally posted by PACETTR@February 18, 2005, 4:32 PM
Mine's on order...
Enjoy
FORD: 2005 Mustang
ISSUE:
ACTION:
WARRANTY STATUS:
EDIT...TSB
Mine's on order...
FORD: 2005 Mustang
ISSUE:
ACTION:
WARRANTY STATUS:
EDIT...TSB
As of tonight, here is a list of all 11 available:
Technical Service Bulletins
2005 MUSTANG - US (English)
05-4-8
FUEL FILL SLOW, OR DIFFICULT TO FILL
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-20-7
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-14-7
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
________________
TSBs found:11
05-4-8
05-3-1
04-26-22
04-26-16
04-24-20
04-24-14
04-24-5
04-20-7
04-16-1
04-14-7
04-9-6
________________
TSBs found:11
Originally posted by Blk05GT@February 18, 2005, 9:17 PM
Any way to determine what tank you have?
unnoticedtrails
7/17/17 11:10 AM
