Engine swap question 09 in a 06
Tms Mustang Member ------ The Customizer!
I just have a quick question.
I'm swapping in a 09gt engine into my 06gt.
I know things changed in 07.
What I would like to know is what coolant hoses do I need?
No one seems to give me a straight answer.
Would these work or do I need something else/more?
Or is there a better option out there?
https://www.mishimoto.com/ford-musta...kit-07-10.html
This is my first time swapping an engine so I'm still learning. Also found some more differences that no one ever mentions which I was able to figure out.
Maybe This Answer Will Help! When Putting a Roushcharger in My 07 I Had To Use a Kit To Go Back to the 05-06 Thermostat Style because Kit Was Designed Originally For 05-06. So We That Being Said. It is Your Choice to Use Either Style. I Would Think the 06 CAR Style would be Easier VS The 09 ENGINE Style.Because You Already Have All the Parts And Simply Need to Replace Worn Out Exisiting Parts. With The 07-09 You Have To Have any Different Items Your Car Does Not Have! I Do Prefer the Later Stat Style But Really How Often are You Fooling With it! It's Been a Lotta Years and I'm A Bit Fuzzy Today so if Anybody can Think of Something Else Please Chime In!Oh I Remembered Your Old Post Here
Did You Get the Later Crossover ??? I Would Say the Deciding Factor is Which Crossover You are Going To Use!
https://themustangsource.com/forums/...r-pipe-549644/
I Wish I Still Had Dealership Parts Catalog Access. I Could Do a Check & Cross Check on Differences So Much Easier Than Existing Online Catalogs.
Mgb,
KC
Thank you for the reminder KC. I actually forgot about my other post. The link you provide to that guide is actually really helpful. I want to move away from the 05-06 style and use the simpler 07-09 style. Everything I need is in that guide. Thanks again.
You Are Such A Talented Guy I Can't Wait to see the Final Results!
If you Get an Elusive Part Just Ask & I will Search for You!We Get By With a Little Help From Our Friends!
Mgb,
KC
