Engine Dress up
Old Jul 28, 2005 | 04:51 AM
Big Poppa's Avatar
Here you have it. The BMR strut tower brace with intake cover. The strut tower brace sits directly on top of the intake cover, with no space between. Actually it works good and haven't had any problems. I installed washers under the strut tower brace to give it a little more clearance, but had to take them out because I cross threaded on of the nuts and didn't have enough threads. Some lock tight fixed that. Be careful if you try this setup, the nuts and studs on the car are really cheap.
Old Jul 28, 2005 | 05:56 AM
scottma's Avatar
Is that a 4.6 High Performance Emblem? It looks like the same emblem I went with. I am glad to see that the BMR fits. I think that that is the tower brace I will go with also.
Old Jul 28, 2005 | 07:25 AM
MTAS's Avatar
Gregory that looks awesome The BMR stuff is really nice.
Old Jul 28, 2005 | 07:51 AM
BLAKE's Avatar
Aren't you worried that the intake cover will get damaged over time as the engine torques over on the mounts?
Old Jul 31, 2005 | 09:34 AM
Big Poppa's Avatar
Yea I thought about that but have no solution. Someday I will get a blower from Saleen and I will have to ditch the cover and the brace, hopefully it lasts until then.
Scottma
Yes thats the 4.6 Hi Perf emblem.
Thanks everyone for the comments
Old Sep 7, 2005 | 01:22 AM
silverado's Avatar
I slid a seat belt pad across my steeds brace for protection. Works well and can withstand the heat....no problem. Or you could slip on some wrist bands, or cut the ankle part of a tube sock and put that on
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
