Engine Dies...Help
Old Aug 14, 2014 | 10:01 PM
mt819's Avatar
Engine Dies...Help
I have 08 V6 car. Today car died on road. Turns out when I turn on headlights, turn signal or hazard lights the engine immediately dies. Then the engine light and battery light turn on. Also when I turn on headlight switch parking lights and headlights do not turn on but tail lights turn on. I am baffled. Any ideas?
Old Aug 15, 2014 | 01:42 AM
KushBandit's Avatar
Have you checked your alternator?
Old Aug 15, 2014 | 03:56 AM
Wild5.0's Avatar
Yeah check your alternator. If you have a multimeter check your voltage at the battery while car is running. It should read around 13.4-14.6. If reading is lower you will most likely need a new alternator.
Old Aug 15, 2014 | 06:54 AM
stupidgenius36's Avatar
Just Plain Rude!
Electrical issues are common. Go to AutoZone/etc. and have them check your battery and alternator. That will most likely fix your issues.
Old Aug 15, 2014 | 09:44 AM
x2 on the autozone thing drive on up there if you can. Test your battery voltage before you start it too. Your battery may be shot as well.
Old Aug 15, 2014 | 11:39 AM
mt819's Avatar
well after a more in depth search of the engine compartment the issue was a ground wire. thanks for all the responses.
Old Aug 15, 2014 | 11:42 AM
oh man thats no fun
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Evil_Capri
Sep 11, 2015 08:39 AM
